Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 17-02-2005, 18:20
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Unhappy Help with Joystick connections
Hi,
I'm really a programming person, but I got stuck with the job of wiring our control board. I had a soldiering person help me attach the wires according to plan.
My problem is that, although the wiring seems correct and without shorts, I am getting an "Aux Fault" light on the OI when I plug it in.
Do you know all the reasons that may cause this to happen?
I will try to add a picture of the wiring between the two joysticks. I was told that I should wire them in series (ground pins 1,4 in the first joystick to power pin 12 in the second joystick. Is this how you are supposed to use them. It seems like it would not work if you simply connected the +5 Aux Power directly to both joysticks and then connected all 4 grounds back.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Problems hooking up a joystick to edubot Salik Syed Programming 2 24-03-2004 23:56
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
