Go to Post Bring on the competition! And of course the dancing. :D - booton [more]
Unread 17-02-2005, 18:49
wildabyss wildabyss is offline
wildabyss is an unknown quantity at this point
To control motor's rotation...
Hi
I'm trying to control the motor's rotation with a button
I want the motor to turn certain degrees when a button is pressed
so i built a function called MotorDegree, and used For loop to control the rotation. [pwm01 = MotorDegree(p1_sw_trig)]
But it appears that the motor's movement (pwm01) doesn't require the button's activation (p1_sw_trig). It turns automatically once the robot initiates.
I used If command in the function so that the function runs only if the trigger is pressed (when it's 1 or above 0)
What is wrong?
Invacare control system, UI? Jacob Morgan Control System 0 24-10-2004 16:54
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
