Controller Problem
I uploaded the default code with 2 changes, a printf in autonomous that says we are in autonomous, and a printf in manual to say we are in manual
When I load IFI terminal it initializes and does nothing else. My team is complaining that it is not hardware, but I do not believe them. Any suggestions? |
Re: Controller Problem
Are you getting a code error LED on the board?
No
is your oi connected? ive had issues with printf before, but i think i remember needing the oi to be connected. Not sure though
It's connected
my team is having a problem with the drive motors i think, am told that it is the code, and i don't believe them either, but, well, the pwm the code gave me right being 13 and or 14 and left being 15 and or 16, but isn't working, so what would be the problem there, please help me we r cutting it close, it worked fine till we found out we were suppose to use all 4 victors
from what i have heard from other people, and others on this forum, try to stay away from pwm 13,14,15,and 16, switch to 01,02,03,04 and then see what happens
How are you putting it into autonomous mode? Competition port box?
Is the OI on and running? What lights does it show? Last edited by Mark McLeod : 17-02-2005 at 22:59. |
that is what we had done at the beginning, but then i was given that it didn't work as forward being forward and left being left and all that stuff, so i take another look at the code, and it says,to use those ports, which didnt' work right, until, this was when we were using only 2 victors, 11 and 13 made it work fine, but now that we have 4, can't tell where to put them, since still only two work, and i gotta have it fixed ASAP, due to shipping date being tuesday, the school is tottaly closed on monday for presidents day, so we pack it up saturday and ship it tuesday morning, so i need to find out how to fix it by saturday, and it is like since they didn't have it right in the first place, and sorri, is out first year also, a noobie team, lol |
#10
Nothing is sending it to autonomous, everything is connected
[edit] Our 2004 botcode is working on the robot, but this year's default isn't Well, 2.2 for this year is kinda mostly working occasionally, but 2.4 isn't [/edit] Last edited by doyler : 18-02-2005 at 11:05. |
#11
Yup
#13
Are the radio modems connected?
#14
No, we have it tethered
#15
Make sure your printf commands are using /r instead of /n. /n will cause the system to stop responding.
| Programming Problem: Extremely Frustrating | chantilly_team | Programming | 19 | 12-02-2005 23:00 |
| Speed controllers won't communicate w/robot controller | steven114 | Control System | 12 | 03-02-2005 21:26 |
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| Victor controller problem | llambele | Technical Discussion | 3 | 14-11-2001 23:00 |
