Go to Post Either way, I'll stay a FIRSTer for life. =) - Adare180 [more]
Unread 18-02-2005, 00:15
chippermonky chippermonky is offline
chippermonky is an unknown quantity at this point
a simple autonomous mode question
Well I went digging through the forums which went very indepth with the autonomous mode, but right now I have a very simple question:
How (and in compliant with the rules) am I suppose to go in and out of autonomous mode. Right now, my ideal robot would be one that starts in the "user" mode, and on the press of a button, enters autonomous mode, does whatever it needs to do, and exits autonomous mode after a second press of the button.
Sorry, our team is short on time. I've looked throughout the forums and manuals and couldn't find out how. Thanks in advance.
Unread 18-02-2005, 00:18
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: a simple autonomous mode question
FIRST sets autonomous mode automatically at the start of your match via the Competition port on the OI. Assuming your code is in the right place, everything should be taken care of automatically.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-02-2005, 00:38
the_undefined's Avatar
the_undefined the_undefined is offline
German FES
AKA: Felix Geisendörfer
#1648 (Gearbox Gangstas)
the_undefined has a spectacular aura aboutthe_undefined has a spectacular aura about
I think what he means with right place is this are of your user_routines_fast.h file. Just call your autonmous function from here and you should be fine.
Bye
Felix
Code:
void User_Autonomous_Code(void)
  /* Initialize all PWMs and Relays when entering Autonomous mode, or else it
     will be stuck with the last values mapped from the joysticks.  Remember,
     even when Disabled it is reading inputs from the Operator Interface.
    pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
    pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
    relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
    relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
    relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
    relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
        //robot_control();
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Unread 18-02-2005, 01:54
Thank you both a ton, this clears a lot up for me. Good luck at competition.
Where to insert code Autonomous mode caderader Programming 5 18-02-2005 16:49
How do I enter the Autonomous mode? CompMaster Programming 5 17-02-2005 19:12
Receiving info from OI to select autonomous mode Mr. Lim Programming 21 17-02-2005 00:56
EDU robot autonomous mode dmellich Programming 2 17-03-2004 14:54
Autonomous mode Tyler Olds General Forum 30 22-02-2004 14:31
