Go to Post Remember, never underestimate the determination of thousands of FIRST students! - Jay H 237 [more]
Unread 18-02-2005, 10:12
brownster brownster is offline
#1392 (Team Kinematrix)
brownster is an unknown quantity at this point
Encoder code with hall effect sensors help
I need to know how to exactly use the hall effects with the encoders. I plugged in the output from the hall effects so that left is digital input 1 and the right isdigital input 2. However when i run the autonomous the right wheel behaves properly and the left wheel doesn't. In "pid.h" i changed the code so that left wheel is pwm and right wheel is pwm 10..but that is all i did...i need to know where the quadrature input part is so i can delete it too. If anyone can tell me why 1 wheel is working and the other isn't..that would be really great....thank you!
Unread 18-02-2005, 10:19
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
Re: Encoder code with hall effect sensors help
You are using the hall-effects AND encoders? Why?
Unread 18-02-2005, 11:41
no im using just the hall effects as encoders. I need help doing this using the encoder code. the right side wheel works but the left does not. i just want to know why? and how to fix it? thank you
Unread 18-02-2005, 11:47
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Have you looked at the actual signal coming from the sensor? It might not be working correctly. What happens if you swap the sensors?
Unread 18-02-2005, 13:09
If i swap the sensors the other side the problem just reverses and the other side begins to work correctly
Unread 18-02-2005, 13:17
Software Architect
If the problem follows the sensor, then the sensor is the problem.
I don't know how susceptible the Allegro sensors are to electrostatic discharge, but I know ours were working great one morning and were both dead that afternoon. We decided that encoders are the way to go.
Unread 18-02-2005, 14:01
Well the thing that could really help me right is if you could tell me what i need to do to make the hall effects work if Kevin's autonomous code. then maybe i know if the problem was hardware or not. And sorry i meant to say that the sensor is not the problem..when i switch sides the problem also switches to the other side. So the other sensor...so if anyone could tell me what i need to exactly do to make the hall effects work with the code that would be awesome. like step by step insructions and wehre the code changes are!
Unread 18-02-2005, 20:43
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Exactly the same problem here. I've ruled out the sensors, the code, only thing left is RC. I should mention this is the 2004 RC. It does the same thing on our 2005 one, with different sensors. Which would mean its the code, but its the code directly from the encoder stuff. I don't know what to do abou it...
The sensors are fine, we took a multimeter to the sensors, and we get signal wire changing from 0 to +5v.
Unread 18-02-2005, 22:44
Then i have no idea about it...i really can't find anything wrong with the code...i'm guessing its something to do with the quadrature input..if someone knows anything..let me know!!!!!
Unread 19-02-2005, 00:01
Rookie Year: 1234
http://www.chiefdelphi.com/forums/sh...ad.php?t=34859
Fixed it, read that for details.
Its a kind weird thing that one works and not the other, but that fixed it for me.
Unread 19-02-2005, 09:23
Which printf statement would it be if i'm using Kevins nav code?
How to program Hall Effect sensors. chantilly_team Programming 1 17-02-2005 14:08
Hall Effect Sensor Example Code JJMax7 Programming 6 16-02-2005 02:38
Accelerometer and hall effect sensors brownster Programming 1 13-02-2005 13:36
Where to place Hall Effect Sensors. Moloch Electrical 10 11-02-2005 16:47
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
