Go to Post It's a bit sad, really, because FIRST has already reached other countries and there are some U.S. states that still are unaware of what FIRST is!! - tribotec_ca88 [more]
Unread 18-02-2005, 11:16
the_undefined's Avatar
the_undefined the_undefined is offline
German FES
AKA: Felix Geisendörfer
#1648 (Gearbox Gangstas)
the_undefined has a spectacular aura aboutthe_undefined has a spectacular aura about
atan Problem - Need Help
Hi Guys,
I have a little problem getting the atan function of Team 296's Math Library to work for me. What I need is calculating the Degree my Joystick is looking it by using atan(x,y).
I already know how to use the sin/cos function and how to work with the binary radians (-8,388,608 to 8,388,607) that the functions operate in.
But for some reason the results I get back from atan seem to be different from the one sin/cos give me or in different words: Say behave nonlinear in cases they should:
Here is what I tried (after I had problems with weird results):
Code:
short long brad; int int_brad;
// should give me 8388608/4 Brad = 45 Degree back, according to the way sin/cos work
brad = atan(1,1);
// Transform short long to int to be able to print the result with printf();
// Drop the last 8 Bit (Should be 32768/4=8192 after that)
brad>>=8;
// Put value in an Int
int_brad = (int)brad;
// Print the Value to the Screen
printf("int_brad = %d\n", (int)int_brad);
// ====Output===
int_brad = 8511
Converting this into Degree I got 46 Degree but I didn't like that because sin/cos worked way more accurate for me than this. So I tried different Values and that showed that there must be a problem:
Code:
atan(1,1) = 8511        (should be 32768/4=8192         = 45 Degree)
atan(1,-1) = 24256     (should be -32768/4=-8192      = -45 Degree)
atan(1,0) = 1799        (should be 0/32768=0)            = 0 Degree)
atan(1,2) = 1799        (should be 11548)                  = 63.43 Degree)
atan(1,-2) = 1799       (should be-11548)                 = -63.43 Degree)
atan(2,1) = -1800       (should be 4736)                   = 26.57 Degree)
atan(2,-1) = -30969    (should be -4736                   = -26.57 Degree)
Anybody out there that has an Idea what I could do wrong or somebody that already has atan working?
Thanks for your Help,
Felix
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
