Go to Post We will all win in the end. - JaneYoung [more]
Unread 18-02-2005, 17:13
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Victors controlled with joystick Buttons
For the motor that drives are arm I am trying to use PWM9 with the hat on the port 1 joystick. Using the default code when I turn on the robot the motor spins, When i push the hat forward it spins faster and when i push it backwards it spins alower, Any idea what the problem may be?
James
Unread 18-02-2005, 21:28
Matt_Kitts's Avatar
Matt_Kitts Matt_Kitts is offline
AKA: Kitts
FRC #1370 (Blue Charge)
Team Role: Mechanical
Matt_Kitts is on a distinguished road
Send a message via AIM to Matt_Kitts Send a message via Yahoo to Matt_Kitts
Re: Victors controlled with joystick Buttons
check your calibration
Unread 18-02-2005, 23:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The "problem" is that the hat is not a joystick. Use the Dashboard program to see what analog values it provides on the wheel input. I don't have the actual values handy at the moment, but ours is something like 95 for down, 255 for up, and 43 for center. Left and right have specific values too. You can also detect simultaneous left/down and right/down if you want to, but the up resistor is of low enough value that it overpowers the left and right and always gives 255.
(I don't think the default code does anything with that value, though. I suspect your joystick just needs to be recentered with the little trim control to the right on the base, and you're actually moving the joystick itself when you try to use the hat.)
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
joystick buttons and a quick question h0x4r Programming 2 17-02-2005 00:18
Victors, Default code, & joystick configuration Vermatitis Control System 4 27-01-2005 16:01
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
