Dumb question about wiring custom controls
Everything that I run from the control ports has to be attached to the ground pin right? Whether it be a potentiometer or a switch it needs to have 5v to the 5v pin the signal pin connected to a signal pin and the ground pin connected to the ground. Do I just end up attaching all those grounds and solder them to the one ground pin/s?
Re: Dumb question about wiring custom controls
Switches connect from ground to the signal input on the OI port. Pots connect from +5 to the signal input on the OI port, with no ground connection.
All the +5 pins and grounds on the OI are connected together, so you can use as many or as few as you want. It's probably both safe and convenient to keep all the controls on each joystick port separately powered/grounded. |
| Wiring Question | SPARKY1688 | Electrical | 3 | 18-02-2005 13:22 |
| Wiring a Custom Operator Interface Box | JWilliams101 | Technical Discussion | 2 | 12-02-2005 22:36 |
| Pressure Switch Wiring Question | Matthew_H | Electrical | 4 | 16-02-2004 01:25 |
| A question of controls | Duke 13370 | Electrical | 8 | 11-02-2003 14:47 |
| So what's in YOUR Custom Circuit this year? | kmcclary | Technical Discussion | 7 | 10-04-2002 12:20 |
