Go to Post The awards may or may not come...but the real trophies are the students. - David Brinza [more]
Unread 18-02-2005, 18:53
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
Double Solenoid Help
We have a double solenoid hooked up to a piston
It is hooked up to relays 1 and 2
We are trying to make it come out when the trigger is pulled and go back when it is pulled again
What would I have to fix here?
Code:
int pnu = 0;
       if(p3_sw_trig==1 && pnu==0)
	relay1_fwd=0;
	relay1_rev=1;
	relay2_fwd=1;
	relay2_rev=0;
	pnu+=1;
	if(p3_sw_trig==1 && pnu==1)
	relay1_fwd=1;
	relay1_rev=0;
	relay2_fwd=0;
	relay2_rev=1;
	pnu=0;
Unread 18-02-2005, 19:07
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
Re: Double Solenoid Help
Only have taken a quick glance at your code, but you can wire a double solenoid unsing just 1 spike. Look at the spike manual on ifirobotics.com to find otu how to wire. At will also make your code a bit easier
Harker Robotics:1072
http://www.harker-robotics.org
Unread 18-02-2005, 19:21
Rookie / Programmer
#0900 (Infinity)
We don't really have time to put a double on 1 spike, but is there a way to fix my code?
Unread 18-02-2005, 23:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
To fix your code, you also need to make sure that you only process the change once each time the switch is activated.
Code:
  last_trig = 0;
  if (p3_sw_trig ==1 && last_trig == 0 && pnu == 0)
    pnu += 1;
  if (p3_sw_trig == 1 && last_trig == 0 && pnu == 1)
    pnu = 0;
  last_trig = p3_sw_trig;
Unread 19-02-2005, 11:36
Rookie / Programmer
#0900 (Infinity)
I added that, but for some reason I still can't get it working
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
Double Solenoid Leak Darksun Pneumatics 4 18-02-2004 22:52
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
