Go to Post ...it takes a very special kind of person to equate bagpipes with harps. - Kevin Sevcik [more]
Unread 19-02-2005, 11:53
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
Encoder assistance needed
Here are a few lines from Kevins encoder readme.txt
Five things must be done before this software will work
correctly on the FRC-RC:
1) The left encoder's phase-A output is wired to digital input
one and the phase-B output is wired to digital input six.
2) The right encoder's phase-A output is wired to digital input
two and the phase-B output is wired to digital input eight.
In other threads it says to wire the hall effect sensor (4 pins) to pwm (3 pins) with pins 3&4 together.
This nets one sensor and only one pwm connection.
1. Is this Phase A or Phase B?
2. Where do I find the other?
3. Or how is this physically wired.
Thanks,
Phil
Last edited by phillutz : 19-02-2005 at 11:54. Reason: notification of responses needed
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
