Go to Post bedtime? there's no bedtime while chief delphi is up and running! - Alex Cormier [more]
Unread 19-02-2005, 13:02
katkana katkana is offline
that programmer chick
AKA: Gillian Koch
FRC #1412 (Mercedes Metalheads)
katkana is on a distinguished road
Send a message via AIM to katkana
Where to insert new code?
I'm a little confused as to where to insert code of my own workings. It doesn't help that I'm both new to programming and have information from about five different sources floating through my head that each say different things. Any and all help will be much appreciated.
By the bye... the code I'm inserting is a limit code for one of our joysticks--it's too sensitive for the job we need it to do.
Thanks in advance!
~kat
And now for something completely different...
GO DRAGONS!!!
Drexel University, Class of 2010
"The definition of insanity is doing the same thing over and over and over and over again, but expecting a different result." ~ Albert Einstein
"Strength is irrelevant. Freedom is irrelevant. Self-determination is irrelevant. Death is irrelevant. You must comply." ~ the Borg
"Therapy is expensive. Popping bubble plastic is cheap. You choose." ~ Unknown
"We're [engineers]! We're the opposite of people!" ~ pirated from Rosencrantz and Guildenstern are Dead!
Unread 19-02-2005, 13:27
Embok's Avatar
Embok Embok is offline
Seriously now, who is JVN?
AKA: Eric Rene de Cotret
#0188 (Blizzard)
Embok is on a distinguished road
Re: Where to insert new code?
User_Routines
Unread 19-02-2005, 13:34
AKA: Gillian Koch
I knew that, but where exactly in user_routines? I'm trying to keep from messing up anything important, so should i put it directly into the default routine, before the user initialization, or ... ? Where's the best place?
GO DRAGONS!!!
Unread 19-02-2005, 13:39
Embok's Avatar
#0188 (Blizzard)
In the Function Process_Data_From_Master_uP right below where it says /* Add your own code here. */
Unread 19-02-2005, 13:44
AKA: Gillian Koch
You know, that would make sense. I must've missed that line the first fifty times I'd read the code. Thanks for that.
GO DRAGONS!!!
Unread 19-02-2005, 13:47
Embok's Avatar
#0188 (Blizzard)
No Problem, Happy Programming.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Where to insert code Autonomous mode caderader Programming 5 18-02-2005 16:49
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
