Go to Post The best way to brainstorm is to just do it. - EricH [more]
Unread 20-02-2005, 10:02
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Rookie Year: 1997
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Has Any Team Been Able to Find and Cap a Vision Tetra in Autonomous?
Now that the bots are nearly done and the scrimmages are going on, has any team been able to find, lift and cap a vision tetra in the 15 sec autonomous period?
If so are there any mpegs available to see them in action?
Just curious.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 20-02-2005, 10:24
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
Re: Has Any Team Been Able to Find and Cap a Vision Tetra in Autonomous?
there's a thread similar to this:
http://www.chiefdelphi.com/forums/sh...ad.php?t=33475
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 20-02-2005, 20:41
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
I was just going to post about this, actually.
Our lead controls mentor was just asking me to crunch some numbers on the subject. We've found that, if you are starting on the side (inside the blue line), and if your robot goes for the first center vision tetra, and if you measure at 90 degree angles assuming a zero turning radius and no time loss per turn, it is a 39.75 foot journey to be able to be in a position to stack on the center goal.
At 7 FPS--the middle ground between our robot's top speed of 10 FPS and bottom speed of 5 FPS--that takes about 5.7 seconds. Call it six, factoring in other problems.
If we assume 5 seconds to grab the vision tetra--not unreasonable--that gives you 11 seconds.
4 seconds to fight your way to the goal and score the tetra.
And that is assuming everything goes perfectly.
For this reason, the mentor will be putting together some serious numbers in an effort to ask FIRST to extend the autonomous mode to 25 seconds.
That is assuming that no one has had an inordinate amount of success with this issue. So, the question is...have you?
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 20-02-2005, 21:46
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
--Petey
This is one of the reasons that we are not attempting the vision tetra during autonomous. We analyzed the problem and when our programmers did not think there was enough time in autonomous, we abandoned the idea. To change the rules, 2 days before shipping is not fair.
It is entirely possible that many teams will be able to cap the vision tetra. Those teams should be rewarded for their ingenuity and not have to worry about a competitor who can cap in 24 seconds. It is possible that these teams sacrificed pushing power ( or some other attribute ) to enable their robot to cap faster. If more teams can suddenly cap in auto then it will cheapen the accomplishment of those that can do it in 14 seconds.
It is bad enough that we might have to wait until after the shipment date to have a rule clarified, however to change a clearly defined rule this late in the process should be unthinkable.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 20-02-2005, 22:26
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
we too have decided to abandon capping with the vision tetra
and i agree that no rule change should happen to extend the autonomous period
does anyone know how many points you would get if during autonomous you hitted the hanging tetra down to the ground containing it within the big tetra
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 20-02-2005, 22:35
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Our programmers are still at school right now trying to get auto to work. I'm not even gonna be suprsied to find them sleeping on the tech room floor tomorrow when I get there.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 20-02-2005, 22:51
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
1 point for containing a tetra.
However it is worth noting that if no tetra is capped on that goal, you 'own' it for the sake of triple play 10 point bonuses.
Unread 20-02-2005, 22:58
Rookie Year: 1997
so I take it the answer is NO. Nobody has yet to accomplish the feat or is willing to admit it.
WC
Unread 20-02-2005, 23:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
--Petey
Seriously, don't even bother. FIRST won't even consider changing the length of the autonomous mode.
I guarentee you there will be teams that can cap a vision tetra in autonomous.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-02-2005, 23:22
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
We have found much success so far with our autonomous mode. Sorry no mpegs or anything yet...I'll try to get one for tomorrow.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 21-02-2005, 00:05
IndianChieftain's Avatar
IndianChieftain IndianChieftain is offline
FRC #1241 (Theory 6)
Team Role: Mechanical
IndianChieftain is on a distinguished road
Team 1241 was working all 6 weeks day and night to get the camera working and finding the tetra. we succeeded in that task. but trying to get an arm to pick it up off the floor and cap it within 15 seconds was the part that really gave us alot of trouble. 1241 can't cap the VT's, but we are thinking that we will be more succesful in defending the other alliance from capping than we would ourselves.
04-05-Regional Champions - Waterloo (Thanx 1305 and 68)
04-05-Team Spirit Award - Waterloo
04-05-Entreprenuership Award - Waterloo
03-04-Rookie All-Star award - Great Lakes Regional
03-04-Rookie Highest Seed - Greater Toronto Regional
03-04-Rookie All-Star award - Greater Toronto Regional
03-04-Damier Chrysler Team Spirit award - Greater Toronto Regional
03-04-Damier Chrysler Team Spirit award - National Championships
Unread 21-02-2005, 02:24
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
We were gungho about doing the vision part, then the second week we realized are arm design may not be low enough to do it, so the cam got put on the backburner. Last week we decided to use the camera, so i built a quick mount. Our code is a hodgepodge of very simple commands (Find green, when tilt is down lift tetra and find yellow, when tilt is down lower tetra) so no idea if its going to work we were having so many issues with the camera and trying to get it to work today. First too long serial, then a super slow laptop, then a dead backup battery
Honistly i hope they dont change the rules. BUT Next year i want to see a 30sec -1 min automode with 2 min of gameplay, a 3 min game might be alot of fun!
Unread 21-02-2005, 02:31
Nate Edwards Nate Edwards is offline
SWARM Head Mentor
FRC #0957 (SWARM)
Nate Edwards will become famous soon enough
Obviously they wont change the rules, because our robot is alreadly in the crate because we can knock down that hanging tetra and get to the vision tetra and get it high enough in 15 seconds, just not enough to go after the goal, its hard to do, you have to be fast moving, fast tracking and fast at raising the arm, im sure a few teams will be ok at it and might get it on but only a couple will get it capped and scored entirely on the center by the time auto is over. We tried it was pretty much impossible, but nothing hurts to try. We are still very happy with it.
Nate
South West Albany Robot Mechanics
2002 Pacific NW Regional Rookie All Star Award Winners
2003 Pacific NW Regional Daimler Chrysler Team Spirit Award Winners
2004 Pacific NW Regional Johnson & Johnson Sportsmanship Award Winners
2004 Pacific NW Regional Winning Alliance (492 (#1 Seed), 1031, 957)
2003 & 2005 Pacific NW Regional Chairman's Award Winners
2009 Oregon Regional Woodie Flowers Award Winner
Unread 21-02-2005, 02:43
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
[skip over this part]I now have to admit that I was wrong when early in the season I predicted that many more teams would have successful autonomous modes this year than last year. I personally would support extending the autonomous period to 25 seconds, as the point of FIRST is not supposed to be to have a fair competition, but rather to promote learning and whatnot. As it is no one is going to be learning anything except that software engineers are smart, because the only teams that are going to be scoring in autonomous mode are teams that not only have professional software engineers writing their code, but also have engineers designing their robot, and have a lot of luck besides. Ok maybe that is a little bit of a stretch, but the autonomous mode is not supposed to be difficult to the point of impossibility, it is just supposed to be a challenge that can be overcome, and teams that are especially good will not only overcome the challenge, but will go beyond what is thought possible, and will help other teams do the same. Also I think FIRST is moving away from autonmous mode, and is becoming too much of a remote control car building and driving contest.[/skip]
Ok yeah I am done . To sum things up I think that autonomous mode should be extended. If you care why read above.
  #15   Spotlight this post!
Unread 21-02-2005, 03:00
Tom Bottiglieri Tom Bottiglieri is offline
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
As I like to say...
A good autonomous mode is not hard, just tedious. And since it depends on the mechanical subteams, it is hard to get done. We should be able to cap in auto mode, though.
CMUcam autonomous programming kshot Programming 1 17-01-2005 19:18
