Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 20-02-2005, 11:32
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
Help! Can we use small pneumatic cylinders from 2003?
we need to figure out if we can use the small pneumatic cylinders from 2003s robot. there is no time to order from first and we are going to have to strip a previous years robot. if any one knows anything, please help!
justin
Team 302
Unread 20-02-2005, 11:37
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Can we use small pneumatic cylinders from 2003?
If you can post the bore, stroke and manufacturer then we can tell you if its legal of not. A part number will help also.
The bore is the diameter of the piston that extends out and stroke is the length of the piston that extends.
-Michael Dessingue
Unread 20-02-2005, 11:43
Justin_302's Avatar
Justin
AKA: Justin
Team Role: Driver
Re: Help! Can we use small pneumatic cylinders from 2003?
sorry i forgot to post the stroke/bore
its a bimba piston cylinder with a 1 1/2 bore and stroke. part number 171 5-d
Team 302
Unread 20-02-2005, 11:53
Rookie Year: 2000
It would appear if those are the true specs to be legal to use, i would for reference and a final answer though ask it on the Q&A message board. Just remember to include the specs and any information you can.
-Michael Dessingue
Unread 20-02-2005, 13:13
Justin_302's Avatar
Justin
AKA: Justin
Team Role: Driver
i will check into it some more...thank you
Team 302
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
small pneumatic valves technic master Technical Discussion 8 07-10-2004 19:18
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
Custom pneumatic cylinders duckshepherd Pneumatics 7 24-01-2004 20:39
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
