Go to Post A FIRST door is always open. - Chris Fultz [more]
Unread 20-02-2005, 13:09
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
1 Megohm Potentiometers
We've got three "1 Megohm" potentiometers, that we were planning to use to find arm position. If 1 Megohm = 1,000,000 Ohms will these work? I was under the impression we needed 100K potentiometers, which by my reasoning means we are a factor of 10 off. If these will not work, where can we get pots that will work today?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 20-02-2005, 13:35
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: 1 Megohm Potentiometers
FIRST suggests that the POT should not be more than a 100k Ohms. Yours is 10 times more, i would suggest that you use a 100K one. Too much resistance in the circuit will come out as a value of 0 voltage to the RC. As in, if there is only 0.5 volts flowing through the RC then it reads it as 0 Volts. It is a good idea to stay near the 100 K mark.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 20-02-2005, 13:36
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
You need 100K pots,
We used Bourne product #3540S-1-104
http://www.newark.com/NewarkWebComme...KU=01F8344&N=0
I think its also available at mouser (www.mouser.com)
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 20-02-2005, 21:34
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
You do not need 100K pots, but you may not have very much luck with 1M Ohm pot. The only way to really know is to try it. You only need 100K pots on the OI, we use a lot of 10K pots on our RC without problems.
Unread 20-02-2005, 23:16
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
If you needs the pots quick Radioshack carries 100K and 10K in their retail stores.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 21-02-2005, 06:20
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Just to clarify-
You may use any value pot on the bot, assuming everything else is equal. Some values work better then others. 95 uses 10k's mostly. It's a common value among the pots we like to use. 100k works well to.
100k pots work on the OI best, but it is no longer a legal matter what you use. IFI has posted a range of values that it suggest you stay in. I believe it starts at 250, and goes up to 10k, but don't quote me on that. I would stick with 100k for the OI. All the pots in the joysticks are 100k.
I would suggest you go with a 10k - 100k pot. You can pick them up at radio shack, although they will be pretty cheesy. If your not worried about the quality to much, you can get some Tuesday. I would go with those, and order some higher quality pots as a replacement if the radio shack units turn out to be to cheesy.
-Andy A.
Unread 21-02-2005, 11:25
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
I'll second the vote for 100k pots on the OI - we've had strange troubles with other sizes. I can't say anything about the RC, however. We just started with 100k and stayed there.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 21-02-2005, 14:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Bjorn,
The 1M pot will give some indication of change but the input resistance of the RC and the pot value interact. The 1M may show some change but it might not be linear. (i.e. values per degreee of rotation will vary from one end of the pot to the other and may stop changing at some point) If you need linear, accurate data, stay with the 10K to 100K values.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-02-2005, 14:40
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
Team Role: Coach
Rookie Year: 1997
briholton is on a distinguished road
Originally Posted by Al Skierkiewicz
Bjorn,
Depends on the input impedance of what you are connecting to of course, but Al reminds me of something here - don't forget pots come in linear taper and logarithmic taper. Make sure you get the one you want, and don't buy the cheap ones, they can be really pronounced in what Al is saying above.
"Youth is wasted on the young"...MT
Unread 22-02-2005, 02:05
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Also, at 5V, a 1megohm potentiometer is only drawing 5uA (5 millionths of an ampere), unless I'm terrible at math. From my limited knowledge of E&M, at currents that low, I would be worried about interference from other electrical components. Jumping on the bandwagon, I'd go with 100k or 10k pots to get a reliable signal.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Where to buy good potentiometers? Kirk Electrical 3 12-02-2005 22:23
Using Potentiometers arpus maximus Electrical 5 20-11-2004 16:45
Q about potentiometers Nick R. Electrical 13 07-02-2004 09:13
Working with Potentiometers GrahamS314 Programming 11 02-02-2003 14:34
multi rotational potentiometers jdawson Electrical 8 27-01-2003 08:12
