Go to Post "We'll fix that in programming" - EStokely [more]
Unread 20-02-2005, 17:02
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Toggle switch with pneumatic
does anyone know how to program a toggle switch?
we want to use it as an on/off switch
for up / down with our casters
(we want to toggle the state of our relay by pressing a 1 button)
i tried the code for the toggle and was unsucessful
if anyone has any code, please post and say where the lines go
or if anyone knows where i can find some good code, please let me know
Unread 20-02-2005, 17:49
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Toggle switch with pneumatic
I am trying to remember this on top of my head so here it goes:
Get a toggle switch. Wire Pin 1 of the DB-15 cable to one pin on the toggle switch. Connect the other pin to 10 on the DB-15 connecter. This should work for pX_sw_aux1 (or aux2: not sure) . X is the port number. I would suggest use port 3 or 4, its on the other side of the OI and mostly easier to layout your OI.
With this all you have to do is
relayX_fwd=pX_sw_aux1;
So when the button is in on position the solenoid is active and in off its not. (this will work for a single solenoid)
you can put the code in user_routines.c under where other relays have values assigned. I dont remember the exact line number.
Any questions are welcomed
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 21-02-2005, 14:08
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
yes that will work, but that only goes one direction. Might you alsos want another line relayX_rev=!pX_sw_aux1;? That way itll go both directions
Harker Robotics:1072
http://www.harker-robotics.org
Pneumatics on a toggle switch Idaman323 Programming 3 15-02-2005 18:42
Pneumatic pressure switch M. Hicken Programming 9 29-01-2005 23:35
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
3 way toggle switch programming LeadRiccardoT Programming 3 17-02-2003 02:02
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
