Go to Post And remember, it's the fall semester. So FIRST isn't an excuse for a failing grade (not that it's ever an excuse)! - Billfred [more]
Unread 21-02-2005, 13:39
mrozek mrozek is offline
mrozek is an unknown quantity at this point
With gyro need to access ADC for poteniometer
Kevin in his gyro readme states "This software makes the assumption that when it's running, it
solely controls the analog to digital conversion hardware and
that only the gyro, on analog input one, is being sampled.
". I need to use Get_Analog_Value() on my poteniometer to get its value, which uses ADC - so I need to use another analog input. Does anyone know how to use both at the same time without using Disable_Gyro() since I'll loose my gyro_angle?
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
arm-limitting gyro PD loop producing some strange results ZZII 527 Programming 8 16-02-2005 02:30
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
Programming Gyros goegan31 Programming 33 19-05-2003 20:05
