Go to Post Doesn't make sense, Karthik. ...... You don't scare me, other than the way 1114 normally does. - EricH [more]
Unread 21-02-2005, 19:16
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Victors not synchronized - dual motor train
Our bot uses the dual motor kit tranmissions (2 CIMs left, 2 CIMs right, and 4 884s). We noticed some rather loud motor noise (over and above the loud tranny noises) occasionally when accelerating. The sound is best described as a stalled CIM. We tried using Y-cables for the PWM signal to the two victors on each side. The noise still persists, though, like I said, is intermittent.
Funny thing though, if we wire both CIMs to one victor (yeah, I know its not legal) the problem is solved!
So, if the input signal in the same to each victor (via the Y-cable), how are we sure that the output is the same? Is there a way to calibrate two victors so that they behave the same with identical input signals?
John
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Dual monitor Display setup.... BrianJennings Inventor 6 12-01-2005 20:35
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
Flakey Victors archiver 1999 4 23-06-2002 21:58
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
