Together we can score larger rows than we can apart.
Unread 21-02-2005, 20:48
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Moody Compiling on certain computers...
Working on programming our bot, and I have come to figure out that our school computers will not compile the code correctly. I have MPLAB IDE 7.00 with C18 and the same version of IFI loader on all the computers, but recently when I use the laptop, or one of the desktops, it will say build succeeded, I will load the hex file, and the bot will go into full reverse, but only on the drive wheels, not on the arm. I don't get any feedback in the terminal window, not even a "user processor initialized..." or in our case "for great justice, take off every zig."
However if I use the .hex file I built at home, it works fine. They were built using the same source, the same libraries and linker files, the directories are copies of each other in fact.
Anyone else experience this, any advice? I don't want to have to take my computer to the competitions, it is just to darn big. (50+ lbs, full tower case, caster wheels...) I would probably end up with it tied to the bot and me riding around on it, pulled behind the bot (the sad part is I'm serious, just for kicks, every now and then I'll ride around on it at a LAN party).
Thanks everyone.
Unread 27-02-2005, 20:02
jazzsaxman1988's Avatar
jazzsaxman1988 jazzsaxman1988 is offline
AKA: Hal
#0404 (Distant Rage)
jazzsaxman1988 is an unknown quantity at this point
Send a message via AIM to jazzsaxman1988 Send a message via MSN to jazzsaxman1988 Send a message via Yahoo to jazzsaxman1988
Re: Moody Compiling on certain computers...
I had a similar problem with our robot... the problem ended up being that the directory in which the files were saved was too long, and created an error. The compiler still says "build succeeded" if this happens, but under the hex converter it says "1 Error" or something like that... hope that helps!
So he was standing there, surrounded by sinners, blasphemers, and the devil himself, and he thought to himself, "Well, no one's perfect..."
Unread 27-02-2005, 20:25
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
Rookie Year: 2000
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Well, if it is on a school computer, I assume that you have your unique user id and pass. It might be that the admin hasn't given permission for installing programs and registry entries might not be entered properly. School comps usually have a program(Ours is Deep Freeze) that erase all changes in the computer upon reeboot. That would explain why it works on a home comp but not a school comp. To see if you have Deep Freeze, hit Shift+Ctrl+Alt+F6 I a dialogue appears, it is installed.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 28-02-2005, 11:43
Team Alumni
We have deep freeze on some of our school computers, but not the ones we were using, we had our teacher log onto his account, which has rights to install. The odd thing was the laptop was working at first. It was compiling fine, but it stopped workding, we didn't restart or anything.
I have a friend who is going to bring his spare computer to the competition, so everything should be good.
Unread 28-02-2005, 18:22
Rookie Year: 2000
Sounds odd. Good thing you have a friend with a spare comp You should download Ad-Aware and/or Spybot Search and Destroy and scan with them. It sounds like there might be a virus or something if you didn't even restart.
connect three computers without hub kirov Chit-Chat 9 28-02-2005 18:55
computers edomus Championship Event 11 01-05-2004 10:57
Compiling Problems Chris Hleva Programming 11 20-02-2004 17:12
PCs or Personal computers? Hinkel Y. Chit-Chat 9 12-12-2003 21:14
Ack...computers are addictive evulish Chit-Chat 11 16-11-2002 05:40
