Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. ;) - Billfred [more]
Unread 21-02-2005, 21:47
Team620 Team620 is offline
#0620 (Warbots)
Team620 is an unknown quantity at this point
Simple Autonomous Code
Im having trouble doing autonomous mode. My team and I have agreed to go with dead reckoning. I was wondering if anyone can help me with a simple code to make the motors drive for 1 second and stop i just need help getting started.
After I see a sample code for the motors then I can figure it out this would be appreciated thanks.
-Ryan
Unread 21-02-2005, 22:02
His Eminence's Avatar
His Eminence His Eminence is offline
None #0408 (Roboticks)
Team Role: Webmaster
His Eminence is on a distinguished road
Re: Simple Autonomous Code
Set a simple counter that is incremented every time. Then use conditional statements (like an if statement) to do certain things within a set time. As for actually running the motors, you have to find out which PWM you are using. Then, do something like this:
pwm01=235;
assuming pwm01 is the PWM you are using on your robot.
Know.
Unread 21-02-2005, 22:10
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
I don't have any example code, but you could use the fact that the code is executed once every 26.2 milliseconds and use some decrementing (or incrementing) counters and some if statements...
well, sort of an example, but definitely needs refinement
Code:
count = count + 1;
if (count = 15)
  pwm01 = 180;
  pwm02 = 180;
if (count = 45)
  pwm01 = 255;
  pwm02 = 0;
If I have the idea correct, as count reaches 15, the bot will go forward at a medium speed, then when it reaches 45, it will turn, one side full speed forward, one side full speed back. You get the idea? Just remember that every "count" is 1/38 of a second.
EDIT: got beaten to it... oh well I'll leave it there for the code
Unread 21-02-2005, 22:33
TMHStitans TMHStitans is offline
Robot Operator-2005
AKA: Eric
#1474 (Tewksbury Titans)
TMHStitans has a little shameless behaviour in the past
You can find a very good, yet simple autonomous code on this innovation first link. It not only allows you to go forward, but you can turn in any direction. It is based on time as well so I think it would be perfect for what your looking for. You just have to change the timing, speed, and pwm settings. Its really very simple and useful. You can modify it anyway you like by simply inserting or deleting times, speeds, and directions. You can also use if statements to create switches on the robot wired to the digital inputs that will allow you to write several different autonomous modes. Consider it an improved version of dead reckoning. (dead reckoning++)?
http://www.ifirobotics.com/forum/viewtopic.php?t=75
Unread 21-02-2005, 23:14
#0620 (Warbots)
thank you i think i can program autonomous now
-Ryan
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
