| View Poll Results: Where are you grabbing the tetras? | |||
| Top apex of the tetra (crane, hook) |
75 | 67.57% |
| Bottom of tetra (forklift) |
12 | 10.81% |
| Other |
24 | 21.62% |
| Voters: 111. You may not vote on this poll | |||
How are you picking up the tetras?
Are you picking it up from the top (crane)
Bottom (forklift) Other...? |
Re: How are you picking up the tetras?
We are picking up from the top and then sort of swinging it out so we are grabbing it from the bottom corner. It works well, and it saved us some major arm height.
We're picking it up from the top with a cross-like structure, positioning it over the goal, and lowering the tetra while driving backwards.
Levitation is definitely the way to go.
I'm telling you. |
we're picking it up from the top.
We're picking it up from the top, and then rotating it back so that it effictivly grabs it as if we grabbed at the bottom. I think thats the easiest way to explain it.
We grab it at the bottom, which saves us a lot of time and adds extra length to our arm. We can cap about8 tetras on center goal without needing any extension. However our grabber is not a forklift. It just grabs the bottom corner.
I'd start by moving my eyebrows and asking it "How are YOU doin?"
As Daniel describes, his team's robot seizes the Tetra from the apex. The result is a tetra that is unitized with the arm. |
Our team picks it up eathier at the top, or in the middle of it. Eathier way works well, but holding it in the middle gives us more height.
#10
This is basically our grabber from a top view:
_________________________________ \---------------------------/ \------------------------/ \---------------------/ \------------------/ \---------------/ \-------------/ edit: the spaces didnt show up |------------| it is a triangle at the end of |------------| a bar, this forum doesnt like |------------| text art very much, oh well |------------| |------------| It slides under the top and nestles in the endcaps where all the sides meet. This also centers the tetra automatically on the gripper. We cut it out of solid 1" thich aluminum, it took about 30 min of straight cutting, and a ton of cutting grease also. Last edited by Manavapor : 23-02-2005 at 02:39. |
#11
http://www.chiefdelphi.com/forums/sh...ad.php?t=34995From inside (but top corner)
#12
Upside, we don't have to lift our arm high to put one on - Also, tetra is secure onece it is in the position shown. Downside, we may have to come up with an unusual way to load at the human players station. ![]() |
#13
We use a simple hook to grap the tetra by the apex.
We decided against the use of a complicated, actuating mechanism because we would figure that it would take more time and precision, as well as having to lift more weight on the end of a cantilevered arm. The drawback to this type of tetra grabber is that we have less control over the tetra, and it tends to swing around a little bit. We are planning on adding a horizontal beam to the hook that will keep it from sliding down the arm too easily, and to hopefully steady it a bit. Non-actuating hooks work well, but only if you design them right. |
#15
but how many can pick off the floor, auto loader or dependent on the human station????
we have an arm type thing as seen... |
| YMTC: Descoring Tetras??? | Natchez | You Make The Call | 16 | 10-02-2005 13:00 |
| Question: Missing Tetras in Human Loading Zone? | tribotec_ca88 | Rules/Strategy | 7 | 15-01-2005 15:26 |
| How to Stack Tetras in Inventor | petek | Inventor | 0 | 13-01-2005 11:47 |
| Just where are vision "bonus" tetras placed? | David Brinza | Rules/Strategy | 17 | 10-01-2005 20:50 |
| Manipulating tetras from the ground. | Petey | Rules/Strategy | 4 | 08-01-2005 23:19 |
