| View Poll Results: Where are you grabbing the tetras? | |||
| Top apex of the tetra (crane, hook) |
75 | 67.57% |
| Bottom of tetra (forklift) |
12 | 10.81% |
| Other |
24 | 21.62% |
| Voters: 111. You may not vote on this poll | |||
Re: How are you picking up the tetras?
We can also pick it up from anywhere. Our first claw was a simple ball with a shovel at the bottom, but we tried it and it wasn't as easy as we wanted it to be, so we designed a new claw. Here's a pic of it (after we painted it).
-Daniel |
How well does your grabber work in terms of lining itself up right? We had a triangular guide in our mock up to help guide the three fingers into the right places. |
our team was going to go for the simple hook method, but since we thought of it so quickly, we figured everyone else did too ...which turns out to be true...
so we decided to spice things up. our gripper holds all 3 sides facing you off of the auto loader. first we line up by touching the bottom, then we grasp onto the two sides, this gives us much more control of the tetra so we wont lose it while running around the field and getting hit by other bots. also, it has a certain coolness effect to it, maybe the movie Tremors will stir up your imagination .. we'll post pics later |
Ironically, our team voted on a different manipulator in part because the fixed skewer was too simple. Some teammates wanted to be able to flip the tetra over and carry it over the body of our 'bot, others thought it the skewer would require too much reduction in the arm lifter, and, more importantly, it would have made the pneumatics team unemployed. |
We are using a claw, it looks a little different now that we had to lose some weight but the idea is the same. It uses a 6 inch pneumatic cylinder to rotate it up or down to pick up and release the tetra. This makes it easy to pick up a tetra from the ground, manual loading station or the human player.
We originally went with a forklift design for our grabber. But when we got to competition, we found it was to hard to line up to the auto loader and it was not compatible with the human player.
So on Thursday of SAC we came up with a pneumatic that pushes out to hook the tetra, then retracts to let the tetra slide off. But the pneumatic shaft got bent. So down goes design numero dos. Our third (and luckily final) design is a simple hook with rods coming out either side to stabilize the tetra. It works reasonbly well, but it isn't as good as a well thought out grabber would be. Everything turned out ok though, we played defense for our alliance and got to the finals for the first time in our team's ten year history. ![]() |
#10
Our robot has the ability to pick up tetras off the ground but we barely use it. For any of you who have seen our robot you'll know that we depend on our human player to load us up with up to 3 tetras and cap like a maniac.
-Crash |
#11
We spear it with a piece of pvc, then lift it with a forklift like lift mechanism. It is easy to aim for anywhere inside a tetra and then lift.
#12
We use two servos to extend an arm with 3 fingers that can pick tetras up off of the ground, auto loading station, or human loading station. The entire mechanism can be extended up to 17 feet in the air with a 4-stage telescope with self-contained pulleys.
See: http://www.chiefdelphi.com/forums/sh...ad.php?t=36329 |
#13
I would love to see an exploded diagram of your lifter. |
#14
Team 1370 can pick up the tetra from the bottom or from the top we have to different grippers we find that it is much faster to pick it up from the top but you sacrofes how high you can go.
#15
| YMTC: Descoring Tetras??? | Natchez | You Make The Call | 16 | 10-02-2005 13:00 |
| Question: Missing Tetras in Human Loading Zone? | tribotec_ca88 | Rules/Strategy | 7 | 15-01-2005 15:26 |
| How to Stack Tetras in Inventor | petek | Inventor | 0 | 13-01-2005 11:47 |
| Just where are vision "bonus" tetras placed? | David Brinza | Rules/Strategy | 17 | 10-01-2005 20:50 |
| Manipulating tetras from the ground. | Petey | Rules/Strategy | 4 | 08-01-2005 23:19 |
