Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Unread 21-02-2005, 23:56
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
have a question to ask about Double Solenoids to one spike programming
Code:
		if (top_grab=OPEN) {
		grab_relay_open=OPEN;
		grab_relay_close=CLOSE;
	} else { grab_relay_open=CLOSE;
			 grab_relay_close=OPEN;
does it look somthing like this? well this work? for the double solenoids to one spike programming?
Unread 22-02-2005, 00:39
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: have a question to ask about Double Solenoids to one spike programming
Originally Posted by davelu
Code:
For double solenoid programming.
1) both ground leads go to a ground slot.
2) the hot leads each go to a side of the spike (one to each side).
3)
if(condition)
printf("actuator forward");
relay1_fwd = 1;
relay1_rev = 0;
} else {
printf("actuator back");
relay1_fwd = 0;
relay1_rev = 1;
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 22-02-2005, 00:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
There is another thread similar to this called someting like "how do you wire your double solenoids"
Anyhow, it is more of a wiring thing than a programming thing I think. This is how we do it. We have two double solenoids. We have one relay that actuates the extend function on both, and one relay that actuates the retract function on both. We do this because it is the cylinders for shifting, and we don't mind (actually want) them firing at the same time.
Unread 22-02-2005, 09:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Would it not be easier to use only one solenoid, and connect both cylinders to it with T fittings?
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
General programming question mikesown Programming 1 07-02-2005 16:09
Purchasing double solenoids bob1million Pneumatics 11 08-07-2004 03:17
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
