Go to Post Good luck, and may the FIRST be with you. - Leav [more]
Unread 22-02-2005, 10:33
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Tank Tread suppliers?
Where do you get your tank treads for robots? Im working on a personal robot right now that will use treads, but i havent found a place that sells them. Were do the FIRST teams get them?
Unread 22-02-2005, 10:46
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
Rookie Year: 1998
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: Tank Tread suppliers?
We've always used Breco-flex. They work great but are kinda expensive.
Unread 22-02-2005, 11:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
www.robotmarketplace.com sells a tank tread "unit"
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
