Go to Post Hmmm... I'm pretty sure that twig isn't legal, since the tree it came from started fabrication before kickoff.... - lukevanoort [more]
Unread 22-02-2005, 23:16
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
pic: 222 2005 ball bearing style shifting transmission
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 23-02-2005, 11:28
AKA: Bradley Rigdon
Rookie Year: 2000
Re: pic: 222 2005 ball bearing style shifting transmission
Well since it seems that someone probably wanted to discuss this and never posted; I guess I can post the differences/similarities between this year and last year.
Main Differences:
This year we only have two speeds instead of three.
This year we changed the gear attached to the CIM motor to a 15 tooth instead of a 14 tooth.
Instead of 1/2'' face width gears, we used 3/8'' face width gears for weight reduction.
This year if something goes wrong, which it probably won't, it is much easier to take the transmissions off.
No complex shifting linkages
Last years second gear/speed is gone.
Much lighter.
Similarities:
First gear is still first gear with the exception of changing the 14 tooth CIM motor to the 15 tooth.
Third gear is still third gear with the exception of changing the 14 tooth CIM motor to the 15 tooth.
Still two pneumatic cylinders to shift, but each tranny has its own.
Also not that we changed the gearing between the output shaft and the wheel diameter so that effects our final speed....
Unread 11-03-2005, 14:17
AKA: Bradley Rigdon
Rookie Year: 2000
I have just uploaded 5MB movie to http://www.putfile.com/media.php?n=Robot-05-166 for all to see.
This movie is of our robot in action shifting from low to high and driving around.
You will be able to take a peak at our transmissions at: Annapolis, Philly, and Nats.
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
pic: Shifting Mechanism 222 team222badbrad Robot Showcase 10 05-01-2005 18:01
