pic: 1072 Final Bot
Re: pic: 1072 Final Bot
Great looking bot !!!
It looks as if you can stack pretty high!! Your Tetra gripper mechanism looks especially nice... How does it work?? thanks for posting |
The way the bot is sitting it looks like there is a stabilization device under the bot, is that true or am i just seeing things?
The arm looks good to, good luck. |
no its just the 6 wheel drive system with the center 2 wheels lowered a bit, i forget how much but i think its 1/4 inch.
ahhh ok, I forgot about that whole CG thing for a second to. When arm with heavy object goes up the back part of robot will follow a little bit to.
There is no stabilization device, but we only have a little bit more then a quarter inch ground clearance. Also our frame is made so all heavy component are pretty much 1 inch above the ground, so we're stable enough at full height. |
When I usurp the mechanical lead, the robot will solve Rubiks cubes. *hides from rest of team*
| pic: Team 107 Bot Pic 01 | brent_107 | Robot Showcase | 13 | 26-02-2005 14:49 |
| Team 95 Bot pic, this thing is crazy! | JamesCH95 | Robot Showcase | 0 | 22-02-2005 13:53 |
| pic: Blue Lightning 578 practice bot "Frank" | CD47-Bot | Robot Showcase | 5 | 21-03-2004 11:19 |
| pic: OUr bot ( team 710 ) | CD47-Bot | Robot Showcase | 9 | 04-03-2003 20:47 |
| Team 1072 (Harker Robotics Team)'s bot: Tork | AlbertW | Robot Showcase | 8 | 19-02-2003 13:19 |
