Go to Post We also have a " big daddy" hand riveter. In my estimation one could have assembled the George Washington bridge with it. - DonRotolo [more]
Unread 25-02-2005, 14:32
zack b zack b is offline
zack b is an unknown quantity at this point
emtey tanks crashing arm
using the fesco and bosh valve how do we keep are from crashing down when theres no air(the air in the tanks is empty) behind it. its possible with two fesco valves but they stop working when theres less than twenty pounds behind them I'm not sure if this is true with the Bosch valve
I'm looking for suggestions for making a relief type valve so are arm can slowly fall like a feather win theres know air left in the tanks.
i am aslo wondering if anybody knows how to get the piston to stop in one place.
Unread 25-02-2005, 15:03
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Team Role: Coach
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Re: emtey tanks crashing arm
Gas shocks are legal this year.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 25-02-2005, 15:04
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
A needle valve in there somewhere should help. Say on the exhaust port of the solenoid valve. You should've gotten one in your kit. As for stopping in one place, there's various strategies involving different working pressures, needle valves, and position sensors.
Unread 25-02-2005, 15:18
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Team Role: Teacher
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
you should have gotten some flow controls in the kit. these can be used to control the speed at which a cylinder extends or retracts. if you don't know what i'm talking about, look at the top of page 6 in the pneumatics manual.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 01-03-2005, 03:57
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
The only real way to keep it from 'crashing down' is by using flow controls to regulate the speed of your pneumatics (as mentioned by Roger).
None of the valves in the kit will function under ~25 PSI, as you've found. (an exception being a solenoid valve that has an additional air supply line exclusively to function the solenoid, but none of these are included in the kit and they still wouldn't work if you didn't have pressure in your accumulators.) In order to make the arm come down you'd want to have the valve spring return to the lowering direction, then even without incoming pressure the arm's cylinder will be open to exhaust and able to lower just by the weight of the arm on the cylinder.
In order to use multi-positioning in addition to allowing your arm to lower you'd need to use two valves, one to control direction (set to spring return to lowering the arm) and another to regulate the exhaust of the first (set to spring return to relieving the exhaust from the first).
If you were only interested in multi-positioning and not having your arm lower gradually when your tanks run out then I'd reccomend a three position valve instead for ease-of-use. It is simmilar to the dual solenoid valves included in the kit, only the valve is spring return to a third 'center' position, which can be either all ports blocked (what you want for multi-positioning) or all ports open (if you wanted to relieve the cylinder when its not being actuated). This makes it easiest because it only uses one spike, one solenoid valve, and is also easier from a programming standpoint. There are a number of threads that have discussed this if you are interested in it further, just search.
Jeff
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
