Go to Post Basically: engineering is fun. - Mike [more]
View Poll Results: Do you have a working autnonomous mode?
Places a tetra 100% of the time 31 50.82%
Places a tetra over 50% of the time, but not every time 14 22.95%
Places a tetra less than 50% of the time 8 13.11%
Absolutely not working 8 13.11%
Voters: 61. You may not vote on this poll
Unread 27-02-2005, 12:44
raphael raphael is offline
raphael is an unknown quantity at this point
Do you have a working autnomous mode?
Do you have a working autonomous mode? Please answer the poll and let us know how accurate it is, what the probability is that it will actually place a tetra, and any other important details.
(I know that some of this has already been addressed in other threads, but I want to readdress the issue now, after shipping)
Unread 21-03-2005, 10:56
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Re: Do you have a working autnomous mode?
This year our team has come up with 4 auton modes.
-1. Starts with given tetra in center position-spins turret and caps center goal
-2. Robot starts in corner on auto loader side- robot drives to auto loader, picks up tetra, comes back and gets in position to cap corner goal.
-3. Robot starts on human player side-Hits hanging tetra and moves in position for human player loading.
-4. Robot starts on autoloader side - robot hits hanging tetra and moves in position in front of auto loader.
We do not have number 2 working exactly the way we want it yet due to the fact the robot must be positioned perfectly for it to work, but the others are working fine to the best of my knowledge.
Unread 21-03-2005, 11:42
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
We got autonomous working Friday morning. After that, the Friarbot successfully knocked off the hanging tetra on the side closest to the auto-loader (scoring 1 point) in every match except for one, and that was because our alliance partners had us starting in the center where our autonomous wasn't designed to work from.
Unread 21-03-2005, 11:57
JMH's Avatar
JMH JMH is offline
AKA: Jereme Henson
FRC #1370 (Blue Charge)
Team Role: Mechanical
JMH is an unknown quantity at this point
Send a message via AIM to JMH
Team 1370 has a working autnomous code that works all the time to knock down the hang tetra from ether side with the same code.
Unread 21-03-2005, 12:38
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Our auto (because we didn't have weight for the camera, but that may be changing ) caps any goal on our side, if we start with the tetra, or knocks down either magnetic tetra. Then tries to get to the autoloader... sometimes we just go to the auto loader. Toward the end of Phoenix it was working 4 out of 5 times. Of course on the practice field it worked flawlessly every time
Unread 21-03-2005, 12:47
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
We developed an Auto mode At the end of the day Friday at VCU (I think) that starts with a tetra and caps it on center. We tested it on the practice field. It missed once, because of the way we set it up, and the second time, it put it up but ended up "not fully capped" on the goal. Since the testing we adjusted the speed backing up after it drops down the tetra (which is why it didnt mesh well).
Unfortunately, our partners never wanted us to use it since most of them wanted to start with the tetra and were sure they could be more accurate with it.
Oh well. If we attend an offseason, we plan to execute our secret autonomous weapon. I put 50% in the poll, because after seeing it perform, I'm pretty sure itd work at least 50% of the time.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 21-03-2005, 13:22
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
We had a working autonomous mode when we shipped. We broke it at the Boilermaker Regional when an attempt to fix a joystick scaling problem inadvertently threw the PID tuning for our arm out of whack. A subsequent attempt to fix the PID ended up with it being too underpowered to reach the target position, or even to move at all when it was commanded to move a short distance. I didn't figure that out until Sunday after the regional was over.
Unread 21-03-2005, 13:30
IanT's Avatar
IanT IanT is offline
#1065 (Tatsu)
Team Role: Student
IanT is an unknown quantity at this point
Send a message via ICQ to IanT Send a message via AIM to IanT Send a message via MSN to IanT Send a message via Yahoo to IanT
We do have a working atuonomous mode infact we have a whole leap of them. problem is deciding which oe that we need to use.
Unread 21-03-2005, 16:39
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
We have a working autonomous. The bad thing is if the robot moves (which it did on the first day of our regional) it means that the autonomous code is not working. If it places a tetra then something is seriously wrong!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 21-03-2005, 16:51
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Team 1286 had two autonomous programs working at the Detroit Regional competition last weekend. Both programs swung the alliance tetra in the
direction of the corner goal to knock down the hanging tetra.
Success rate was 4 / 5 in competition, but 0 out of 2 in quarterfinals.
For two competition rounds, I programmed the auto mode to swing twice,
but the swing was too much and I lost the tetra during the swing!.
To prepare for Nationals, we will introduce mode to be ready to cap center
goal if tetra provided in middle (assumes both alliance partners will use
their arms to knock down tetras).
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 21-03-2005, 18:03
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Team 66 has a fairly good autonomous mode, focused on placing a vision tetra on any of the three center goals. At GLR, it succeeded in doing it 3 times during practice day and once during quarterfinals. Otherwise, it stops after pick-up or gets extremely close (I mean that when I say it, EXTREMELY C-L-O-S-E.) So accuracy is 90% when putting the tetra over the goal. But actually capping, less than 50%. We hope to improve that over at West Michigan.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 04-04-2005, 09:38
Matt Fultz's Avatar
Matt Fultz Matt Fultz is offline
Matt Fultz has a spectacular aura aboutMatt Fultz has a spectacular aura about
Cyber Blue's autonomous knocks down the hanging tetra from the goal. It is accurate, I would say, upwards of 100 percent of the time.
I am the son of a Woodie Flowers Award Winner
CyberBlue 234
"Don't confuse self worth with net worth"- Chris Fultz
Unread 04-04-2005, 14:30
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Team 1251, The Techtigers have 3 programs and they all work 100% of the time. For some reason we always use the same one since it seems to be the one that fits our strategie the best.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 06-04-2005, 21:48
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Other: Our autonomous is now working perfectly, but isn't supposed to cap.
(Of course, we don't have anything until Kettering Kickoff)
  #15   Spotlight this post!
Unread 07-04-2005, 08:43
TLonghorns0593 TLonghorns0593 is offline
Student Conceived_Student Achieved
AKA: Eric Leifermann
FRC #0093 (N.E.W. Apple Corps)
TLonghorns0593 is an unknown quantity at this point
Send a message via AIM to TLonghorns0593
We knock down a tetra and then drive out and turn toward either the human loading zone or auto loading zone. Depending on which side we start on.
Forgive me if I'm wrong Sandy. But if I kill all the golfers they'll lock me up and throw away the key.
-Caddy Shack
They need to be green anodized, and then assembled with yellow anodized spinners. ... and then, on the spinners, you can etch "JVN is a dweeb". That would be cool. -Andy B.
2005- Boilermaker Regional Finalists (135 & 876)
2005 - West Michigan Regional Winners(107 & 66)
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
