Go to Post Of course this should be your decision- not the FIRST community's. Take charge of your destiny. - Wayne C. [more]
Unread 27-02-2005, 20:11
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Auton + Functions
heya, right now i'm trying to set up a function to drive forward a certain amount of counts
function is called forward
and it takes integer
declared in user_routines.h
wrote function in user_routines_fast.c
declared the variables in user_routines_fast.c also
Code:
* FILE NAME: user_routines.h
* DESCRIPTION:
*  This is the include file which corresponds to user_routines.c and
*  user_routines_fast.c
*  It contains some aliases and function prototypes used in those files.
* USAGE:
*  If you add your own routines to those files, this is a good place to add
*  your custom macros (aliases), type definitions, and function prototypes.
#ifndef __user_program_h_
#define __user_program_h_
                            MACRO DECLARATIONS
/* Add your macros (aliases and constants) here.                              */
/* Do not edit the ones in ifi_aliases.h                                      */
/* Macros are substituted in at compile time and make your code more readable */
/* as well as making it easy to change a constant value in one place, rather  */
/* than at every place it is used in your code.                               */
 EXAMPLE CONSTANTS:
#define MAXIMUM_LOOPS   5
#define THE_ANSWER      42
#define TRUE            1
#define FALSE           0
#define PI_VAL          3.1415
 EXAMPLE ALIASES:
#define LIMIT_SWITCH_1  rc_dig_int1  (Points to another macro in ifi_aliases.h)
#define MAIN_SOLENOID   solenoid1    (Points to another macro in ifi_aliases.h)
/* Used in limit switch routines in user_routines.c */
#define OPEN        1     /* Limit switch is open (input is floating high). */
#define CLOSED      0     /* Limit switch is closed (input connected to ground). */
                            TYPEDEF DECLARATIONS
/* EXAMPLE DATA STRUCTURE */
typedef struct
  unsigned int  NEW_CAPTURE_DATA:1;
  unsigned int  LAST_IN1:1;
  unsigned int  LAST_IN2:1;
  unsigned int  WHEEL_COUNTER_UP:1;
  unsigned int  :4;
  unsigned int wheel_left_counter;
  unsigned int wheel_right_counter;
} user_struct;
                           FUNCTION PROTOTYPES
/* These routines reside in user_routines.c */
void User_Initialization(void);
void Process_Data_From_Master_uP(void);
void Default_Routine(void);
/* These routines reside in user_routines_fast.c */
void InterruptHandlerLow (void);  /* DO NOT CHANGE! */
void User_Autonomous_Code(void);  /* Only in full-size FRC system. */
void Process_Data_From_Local_IO(void);
/* BKS */                          // Declared my function here
int forward(int counts);             // Called it forward
/* Variables for funcion */
#endif
then i wrote my function here with the global variables, here being user_routines_fast.c
Code:
* FILE NAME: user_routines_fast.c <FRC VERSION>
* DESCRIPTION:
*  This file is where the user can add their custom code within the framework
*  of the routines below.
* USAGE:
*  You can either modify this file to fit your needs, or remove it from your
*  project and replace it with a modified copy.
* OPTIONS:  Interrupts are disabled and not used by default.
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "user_Serialdrv.h"
/*** BKS DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
int count_leftside = 0;
int count_rightside = 0;
int temp1 = 0;
int temp2 = 0;
* FUNCTION NAME: InterruptVectorLow
* PURPOSE:       Low priority interrupt vector
* CALLED FROM:   nowhere by default
* ARGUMENTS:     none
* RETURNS:       void
* DO NOT MODIFY OR DELETE THIS FUNCTION
#pragma code InterruptVectorLow = LOW_INT_VECTOR
void InterruptVectorLow (void)
  _asm
    goto InterruptHandlerLow  /*jump to interrupt routine*/
  _endasm
* FUNCTION NAME: InterruptHandlerLow
* PURPOSE:       Low priority interrupt handler
* If you want to use these external low priority interrupts or any of the
* peripheral interrupts then you must enable them in your initialization
* routine.  Innovation First, Inc. will not provide support for using these
* interrupts, so be careful.  There is great potential for glitchy code if good
* interrupt programming practices are not followed.  Especially read p. 28 of
* the "MPLAB(R) C18 C Compiler User's Guide" for information on context saving.
* CALLED FROM:   this file, InterruptVectorLow routine
* ARGUMENTS:     none
* RETURNS:       void
#pragma code
#pragma interruptlow InterruptHandlerLow save=PROD /* You may want to save additional symbols. */
void InterruptHandlerLow ()
  unsigned char int_byte;
  if (INTCON3bits.INT2IF && INTCON3bits.INT2IE)       /* The INT2 pin is RB2/DIG I/O 1. */
    INTCON3bits.INT2IF = 0;
  else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE)  /* The INT3 pin is RB3/DIG I/O 2. */
    INTCON3bits.INT3IF = 0;
  else if (INTCONbits.RBIF && INTCONbits.RBIE)  /* DIG I/O 3-6 (RB4, RB5, RB6, or RB7) changed. */
    int_byte = PORTB;          /* You must read or write to PORTB */
    INTCONbits.RBIF = 0;     /*     and clear the interrupt flag         */
  }                                        /*     to clear the interrupt condition.  */
  else
    CheckUartInts();    /* For Dynamic Debug Tool or buffered printf features. */
//	BKS
//	Driving Function
	if((digital_io_07 == 1) && (temp1 ==0))
		if(count_leftside < counts)
			pwm04 = pwm03 = 254;
			count_leftside++;
		else if(count_leftside >= counts)
			pwm04 = pwm03 = 127;
		temp1 = digital_io_07;
	else
	if((digital_io_06 == 1) && (temp2 ==0))
		if(count_rightside < counts)
			count_rightside++;
		else if(count_rightside >= counts)
		temp2 = digital_io_06;
	else
* FUNCTION NAME: User_Autonomous_Code
* PURPOSE:       Execute user's code during autonomous robot operation.
* You should modify this routine by adding code which you wish to run in
* autonomous mode.  It will be executed every program loop, and not
* wait for or use any data from the Operator Interface.
* CALLED FROM:   main.c file, main() routine when in Autonomous mode
* ARGUMENTS:     none
* RETURNS:       void
  /* Initialize all PWMs and Relays when entering Autonomous mode, or else it
     will be stuck with the last values mapped from the joysticks.  Remember,
     even when Disabled it is reading inputs from the Operator Interface.
    pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
    pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
    relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
    relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
    relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
    relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
//	digital_io_01			digital_io_02			digital_io_03			digital_io_04
//	Blue		1			Far			1			P1			1			P3			1
//	Red			0			Close		0			P2			0			None		0
if(digital_io_01 == 0){
	if(digital_io_02 == 1){
		if(digital_io_04 == 1){
			forward(138);			// BKS
			// Do position 3b
		if((digital_io_03 == 1) && (digital_io_04 ==0)){
			// Do Position 1b
		else if((digital_io_03 == 0) && (digital_io_04 ==0)){
			// Do Position 2b
	else if(digital_io_02 == 0){
			// Do Position 3a
		if((digital_io_03 == 1) && (digital_io_04 == 0)){
			// Do Position 1a
		else if((digital_io_03 == 0) && (digital_io_04 == 0)){
			// Do Position 2a
else if(digital_io_01 == 1){
			// Do position 3b
			// With diff turn
			// Do Position 1b
			// With diff turn
			// Do Position 2b
			// With diff turn
			// Do Position 3a
			// With diff turn
			// Do Position 1a
			// With diff turn
			// Do Position 2a
			// With diff turn
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
* FUNCTION NAME: Process_Data_From_Local_IO
* PURPOSE:       Execute user's realtime code.
* You should modify this routine by adding code which you wish to run fast.
* It will be executed every program loop, and not wait for fresh data
* from the Operator Interface.
* ARGUMENTS:     none
* RETURNS:       void
  /* Add code here that you want to be executed every program loop. */
* FUNCTION NAME: Serial_Char_Callback
* PURPOSE:       Interrupt handler for the TTL_PORT.
* CALLED FROM:   user_SerialDrv.c
* ARGUMENTS:
*     Argument             Type    IO   Description
*     data        unsigned char    I    Data received from the TTL_PORT
* RETURNS:       void
void Serial_Char_Callback(unsigned char data)
  /* Add code to handle incomming data (remember, interrupts are still active) */
everything builds right but not quite sure if it would work if i upload, just looking to see if anyone could double check my programming and see if i did it right. Sorry bout all the trouble, first yaer programmer with no mentors @.@
thanks for any help given though thanks
-Rookie plz bear with me thanks!
Use of Functions in Autonomous VideoMan053 Programming 11 17-02-2005 16:27
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Overloaded functions jgannon Programming 5 31-12-2004 11:04
Do you write functions for your code? Max Lobovsky Programming 26 11-03-2004 07:04
testing Auton and IR sensors at events KenWittlief General Forum 2 08-03-2004 16:40
