Go to Post Life is too short to spend 40 hours a week doing something you are not enthusiastic about. - Karthik [more]
Unread 28-02-2005, 16:08
Inert Entry Inert Entry is offline
Inert Entry is an unknown quantity at this point
Cool Flow Switch question?
I am looking for a flow switch.
Must be able to operate at >125psi air at max flow >200 lpm.
Must be able to cycle 15-35 times a minute continuous use.
Must be small <2" dia <3" long.
Must be able to operate in any orientation.
Must have SPDT switching at 12vdc.
Would like a fail open.
I have looked at a Malema flow sensor that uses a magnetic read switch.
This is just the type of thing any ideas?
Thanks
Inert Entry
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
