Stock Frame...
Just a quick question to all the teams...who out there used the stock frame material on their robot? If so, how well does it hold up?
Re: Stock Frame...
If you're talking about some sort of bar or square stock, our team used welded aluminum 1" square stock with 1/8" walls, and it is stronger than we could've ever imagined. The bot has 36" lengths of which you can stand in the middle and have no deflection. Overall, the square stock treated us very well, and we remarkably easy to use.
Woo Hoo 100th post (I know, come talk when you have 1,000) |
Re: Stock Frame...
sorry i didn't specify...i ment the stock material FIRST provided..
Re: Stock Frame...
Ah, the kitbot.
1293 went kitbot this year. We've got almost exclusively new people driving it so far (and, even worse, me driving it), and it's held up so far. Then again, we haven't been taking brick walls out. If I remember right, there's video of Paul Copioli's four-or-so-year-old driving the kitbot around. That should be proof enough. |
Re: Stock Frame...
We used the kitbot chasis too, but the arm team wanted to cut the front bar off of the chasis after we loctited the whole chasis, so a guy had to go into it and cut out a part using an angle grinder, and after that day...it has been horribly bending inward...The kitbot chasis is good to use if you don't tweak it that much.
Re: Stock Frame...
We've taken the kitbot through some crash test courses (Not really), we've had our rookies drive, it, I've driven it like I stole the thing, it's held up very nicely. When I saw the extensiveness of the cheese holing during kickoff, I thought that thing would be flimsy, but hey, it's held up (no dents, but many scratches). Too bad we're not using it, the chassis we sent in looks unreliable (it hasn't been field tested, at all)
Re: Stock Frame...
We ummm cut the frame up and used the metal for various brackets and braces for our arm, For our frame well we built a tank.
Re: Stock Frame...
we originally decided it looks a bit flimsey (as compared to 1/4 inch steel tubes....) and it has been converted into our trolley...
Re: Stock Frame...
We put kitbot together, but it twisted around and was flimsy. We decided to use it for are OI controler's frame, but that was twisting the longer it stayed together. I am personally glad that we didn't use it.
#10
Re: Stock Frame...
We are using the kit bot frame and have had minor troubles but nothing that could not be solved and we do not have the second angle in the frame or the large bumper up front.
#11
Re: Stock Frame...
We are using the stock frame with some fiberglass additions, our turret is mounted to it's own frame that is bolted to the main frame. It flexes but that is what we wanted. Still have to finish a few things up at Buckeye. Drive testing went well, lots of tire spin with the stock tires.
#12
Re: Stock Frame...
We used the kit frame material with welded joints instead of bolting it together and welded 1" box on top for the superstructure. That stiffened it up nicely. Had no problems with it at our regional.
#13
Re: Stock Frame...
We used the kitbot, and the gearbox too. In fact, all we did was switch to 6" wheels and move them up for lower ground clearance. It is awesome, and let us drive by the second week. It as enough twist to be good. You want all four wheels driving all the time, so a little warpage is good.
#14
Re: Stock Frame...
We used the kitbot stuff for our cart. Our bot was made from 2"x3" 1/4" wall thickness rectangular aluminum tubing. It was heavy, so a little mill work, and we got underweight. But the bot still looks small without the lexan on.
#15
Re: Stock Frame...
Team 549 used the kitbot frame this year, but added a 1" aliminum extrusion frame on top. We havn't had any problems with it (we took some very hard hits and also gave a few at BAE). i know of a couple teams there that had problems with theres twisting.
| Best frame building material | superbeano2004 | Technical Discussion | 59 | 29-04-2005 08:43 |
| who has combined PVC tubing for thier frame? | Alex Cormier | General Forum | 8 | 12-12-2004 19:47 |
| Voltage on Frame | Greg | Electrical | 31 | 02-03-2004 13:49 |
| Beacon and 10 Point ball PVC frame dimensions | MrB | General Forum | 2 | 28-01-2004 08:35 |
| Rendering Tips | Tyler Olds | 3D Animation and Competition | 27 | 16-10-2003 01:32 |
