Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
Unread 01-03-2005, 14:38
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
And the Wheel Goes 'Round and 'Round
This year we used the KOP wheels, but Next Year I would like to see our team upgrade. Today's big question: what are the best wheels if you want to build a Big Dog Chassis that really grips and goes?
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 01-03-2005, 14:43
zdeswarte's Avatar
zdeswarte zdeswarte is offline
AKA: Zack
None #1240 (LHS Robotics)
Team Role: Electrical
zdeswarte is on a distinguished road
Send a message via MSN to zdeswarte
Re: And the Wheel Goes 'Round and 'Round
It seems like those Omni-Wheels are really good for moving. They're expensive, though, so a lot of teams were talking about how they made them with their own plastic molds for a lot cheaper. I would reccommend those wheels out of all of them, probably made with a poly-urathane (sp?) type plastic. Just from roller-blading experience, that type of plastic sticks really well to most floors. Hope that helps...
Unread 01-03-2005, 14:46
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
for purchased wheels with lots of traction, I like the skyway pneumatic knobbies. I believe they're 6.75" in diameter and they have a tread that's about 2" wide. They give tons of grip, but watchout for not being able to turn due to gearing.
You can make your own fairly easily by taking the KOP wheels, mounting them up on a lathe, and turning the thread down until it's flat. You can then glue/bolt/otherwise attach your favorite traction material to it.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-03-2005, 14:52
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
If you don't want to do any work yourselves and if you don't want the bouncing often associated with pneumatic tires, you can buy tread-less wheels with neoprene or gum rubber. Both substances really grip well, but you have to make sure to keep their surfaces relatively free of dust and grime.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 01-03-2005, 15:18
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
/me points at last years bot
it has 3i nch thick weheels made from standard red/white plywood, 25mmx3. Then covered in a really grippy rubber. Soo grippy we couldn't turn, but went really really really fast in a straight line... it still didn't turn when we took the rubber down a lot and sloped it so it could stay on the middle platform....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 01-03-2005, 17:26
F-14tomcat222's Avatar
F-14tomcat222 F-14tomcat222 is offline
AKA Nosedive
AKA: Justin Sickler
FRC #0222 (Tigertrons)
Team Role: Mechanical
F-14tomcat222 is an unknown quantity at this point
If you want to keep your turning you might think about using gum rubber rollers on omni wheels.
One of my favorite websiteshttp://www.fas.org
Unread 01-03-2005, 19:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I'm not sure what kind of "upgrade" you are looking for but a lot of teams use McMaster Wedge-Top Incline Conveyor Belting for tread. Is is about the most grippy stuff you can get; you don't have to use a very wide wheel. Many teams put the skyway wheels in a lathe and turn them down just until the tread is flat, and then screw this stuff on. The one problem is that this stuff is so grippy that your robot will not turn unless you have 6 wheels with the center wheel lower or a different kind of wheel on the opposite two.
In 2003 we used the Skyway beadlock wheels with the standard foam-rubber tread that comes on them, turned down until they were flat/smooth. They look really slick, but grip really well. As long as your track width is more than your wheelbase, these turn okay.
Unread 01-03-2005, 20:58
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
This year we are using 6 in Colson wheels with aluminum hubs. They are built tough for "Battlebots" but they sure work well for our application. I can barely push our bot sideways. The only problem they are very expensive at $50 a piece and we are using six of them. We ordered them from CNCbotparts.com.
Unread 02-03-2005, 00:07
Team Role: Teacher
I'm not sure what sort of machining capability you have but the wheels without hubs are available for much less here http://robotcombat.com/marketplace_colsons.html
EDIT: And here are some very similar wheels with hubs for cheap, but the hubs are Delrin.
We have used the 6" ones direct on this motor before in a special project without problems, but it was not a competition robot (did not engage in pushing matches). Also, it should be noted that there were two wheels per motor, one on each side.
Unread 02-03-2005, 02:05
Thanks for all the suggestions, folks. I'm still collecting them...
Unread 04-03-2005, 21:46
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Does anyone know any really quick fixes to traction? We have the 8" skyway wheels and unfortunately put them in the back, so when we hold a tetra alot of weight is taken off the wheels. We ziptied velcro strips to the wheels but they wore out quick. We also cut grooves, which helped. What kind of easily attainable substance could we ziptie on?
If you have any good tractiony stuff on hand, that would be sweet if you dropped by team 1093 at VCU tomorrow morning.
P.S. we also heard that coating them in wd-40 makes them sticky when they dry, anyone tried this?
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 04-03-2005, 21:53
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
FRC #0033 (Killer Bees)
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
We used 4 these last year along with a pneumatically activated caster plate which raised our back end a 1/4 inch, which allowed us to have 2wd and 4wd.
Unread 04-03-2005, 23:26
AKA: Allen Gregory
About quickly applying traction, last year we added zip ties to our front wheels to limit are traction and in back we zip-tied pieces of pneumatic tubing rapped in surgical tubing to give us more traction. They also acted as cleats to climb the step but they did provide more traction.
Unread 05-03-2005, 07:13
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
The following link show a photo of our wheel config this year. With the belting material donated to us, these wheel will provide all the traction you would want for the powered drive wheels. The photo caption shows the cost advantage as well.
http://www.chiefdelphi.com/forums/pi...10&quiet=Quiet
  #15   Spotlight this post!
Unread 08-03-2005, 16:51
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
This year we used the same wheel we have used for the past two years. They are pneumatic 6.75" mountain board wheels. They give the best traction Ive ever seen and being pneumatic you can adjust the pressure to get more/less if you need it. They are really great. My freshman year..wow 5 years ago. Me and a couple of the guys made a "traction-o-meter" haha. we made a box with a shaft that you put a wheel on and then had a string attached to a force meter and found out the force it took to pull various wheels over the carpet. Anyway another good wheel is wrapping conveyor belt material around the wheel with some epoxy and then screwing them or pop riveting the ends together. We used that type for the 2002 game and it seemed to work well.
Bash at the Beach - DIRECTIONS? KathieK Off-Season Events 3 19-09-2003 12:45
The Stanley Cup playoffs thread.... D.J. Fluck Chit-Chat 53 09-06-2003 22:38
The key to this year's game (long) archiver 2001 6 23-06-2002 23:05
The background seen round the FIRST world archiver 2001 2 23-06-2002 22:14
The Society for More Qualifying Rounds archiver 1999 47 23-06-2002 22:05
