Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 01-03-2005, 21:58
mpf312's Avatar
mpf312 mpf312 is offline
mpf312 is an unknown quantity at this point
Pit crews, how many students?
this may seem obvious to some, yet what is the forula or steps taken to decide how many students are in your pit crew?
Unread 01-03-2005, 22:33
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: does anyone know the steps that result in how many students you have in your pit
Depends. Your pit crew should consist of as many people as you need to fix things on the robot, either mechanical or softwarical(I don't think that's a word). You probably want at least one member of each sub-team. If you don't have sub teams then you want at least one member who knows the ins and outs of a part of your robot. I would suggest a core team of between 5 and 10 people for a team of moderate size. Use the rest of your team as scouts and our team spirit people.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 01-03-2005, 22:34
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Start with 100 square feet minus table minus workbench minus minus toolcart minus robot, divided by elbow room.
Last year, it worked out to about five people in our pit with room to work on the robot, plus maybe three others squeezing into the corners working on other things.
Unread 02-03-2005, 00:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: does anyone know the steps that result in how many students you have in your pit crew
I think it matters more on who the people are, not how many people there are. I believe last year we had pit schedules, where everyone took shifts in groups of four for a couple hours at a time.
Unread 02-03-2005, 08:43
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Pit crews, how many students?
Depends what needs to be done. If theres an electrical problem the electrical guys will come on. If its mechanical, mechanical guys. If its something easy like removing skins the mentors usually try to get other people to help.
The basic pit crew is usually like 3 kids plus a couple of mentors though.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 02-03-2005, 09:15
Unsung FIRST Hero
mrs. p mrs. p is offline
FRC #0233 (roccobot)
Team Role: Teacher
Rookie Year: 1999
mrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud of
we have 4 students devoted to the inner workings and repairs (when necessary) of our robot along with 1 adult. there really isn't a lot of room in there for more.
Attended:
Regionals KSC, UCF, UTC, Philadelphia, Colorado(2), Toronto, Seattle, Boston(2), NYC, Las Vegas, Hawaii, Los Angeles, Washington D.C., Bayou, Silicon Valley, Chesapeake
Championships: Disney, Texas, Atlanta, St. Louis
Off-Season: IRI, Mayhem, Robot Rodeo, TNT, Panther Prowl
Real Men Wear Pink
Check out www.roccobotics.com
Please visit www.thepinkteam.org
Unread 02-03-2005, 09:25
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
What my team does, and it works well, is we have a senior student designated as the "pit crew chief" and he/she gets a roster of about 10 people on the pit crew. They select 1-4 other people to help fix the bot depending on what broke in the last match. This does not including programming tweaks which are ongoing.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 02-03-2005, 09:32
spadercool spadercool is offline
AKA: Ryan Phillips
FRC #1180 (Atomsmashers)
Team Role: Student
spadercool is an unknown quantity at this point
Our team has the pit crew chief, and builders as fixers in case of repair and knowing where things are and cleanliness and neatness are big factors. I am the pit crew person in charge of neatness and cleanliness and safety glasses
Yay student mentors. Proud EagleScout
Unread 02-03-2005, 09:41
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Should also throw one more thing out there: the pit crew should also have two people who can answer questions from judges who roam the pits. <- hint hint
Unread 02-03-2005, 15:19
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
It would probably work better if everyone on your team could answer the judges questions, instead of haveing one person dedicated to doing that job. I think it might impress the judges a little more, also.
[Qoute=iCurtis] ... softwarical ...[/quote]
if it wasn't a word then, it is now.
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 02-03-2005, 15:31
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Here is the break down that we do on MOE, I know we shouldn't really talk about people in the pits, sparky knows what i am talking about...,
1 student from
Electrical
Programing
Pneumatics
Drive train
Arm
Lifter
and i think 2 students from general mechanical stuff
Also we have between 2-4 ambassadors for the judges.
I know thats about 10 people and can get to be alot, so when the bot is looked at after the match and there is no programing problem, out they go and etc..
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 02-03-2005, 15:38
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
we have a few mentors from drives, electrical and then 2 students or 3 from each sub team like drives, electrical and elevation. also have one pit crew chief which i was last year and will be at Nats, i will be training fellow juniors on how to do the Pit Crew Chiefs job so they can do it next year when I'm off to college. good luck everyone!
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 02-03-2005, 15:45
Pat234's Avatar
Pat234 Pat234 is offline
None #0234 (www.cyberblue234.com)
Team Role: Human Player
Pat234 will become famous soon enoughPat234 will become famous soon enough
On 234 we have about 10 people in the pits throughout the competition
2 manufacturing students
1 electronics student
1 programmer
2 engineers
4 students to talk to judges and run errands around the pit area.
Throughout the competition we have scouts and strategy team students in and out of the pits and more manufacturing students and engineers if there are major problems that need to be fixed.
Unread 02-03-2005, 16:34
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
Team Role: Coach
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Team 1208 has a 6 member pit crew.
2 mechanical team members
1 electrical team member
1 programming team member
1 total system expert
1 jack-of-all-trades/gofer
  #15   Spotlight this post!
Unread 02-03-2005, 16:44
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Team Role: Coach
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
I know that all teams are different. Our team is a "club activity" so we have to allow any student to participate that wants to. As such, we have a number of students who have no clue about our own robot, let alone about the ideals of FIRST. We do not allow these students to meander around our pit area at all since we don't want them talking about things they don't know about with judges or anyone else that happens by. Only the most dedicated members are allowed to hang in our pit and even then we occasionally ask them to go elsewhere when things get crowded.
We designate certain students to talk to judges and we rehearse them so that we are sure that we know what they're going to say.
It sounds good to allow everyone to talk to judges but, at least on our team, that is a pretty unrealistic scenario.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Students design robots, beneficial technology Billfred FIRST In the News... 0 07-02-2005 01:32
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 09-04-2004 21:12
Need help inspiring students? Anthony Towne General Forum 2 07-10-2003 06:29
Qotw [12-01-02]: policy on students... Ken Leung Rumor Mill 11 06-12-2002 15:38
