Go to Post Or, to put it another way: It's a sport where you build your own athlete. - EricH [more]
Unread 02-03-2005, 18:54
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
Rookie Year: 2000
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Look-Up Table
Would this concept be valid:
table(1)=5;
i=1
j=0
j=table(i);
"J"should return 5.
In BASIC, I would have to set the start to be 0, use a dim to se ther range to X. Is this necessary in C?
Thanks In Advance
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 02-03-2005, 19:47
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Question Re: Look-Up Table
Originally Posted by amateurrobotguy
table(1)=5;
i=1
j=0
j=table(i);
"J"should return 5.
Could you please give more detailed examples next time?
At least show all variable declarations and functions with the important algorithm chopped off.
I'm sorry, but the code pieces you show aren't detailed enough (they don't show types or declarations -- just use bogus numbers or something)
I assume what you have in the code is something like:
Code:
/* Make sure to initialize your array. */
/* int variable[LENGTH]={val1,val2,val3,...} */
int table[10]={3,2,1,6,5,4,9,8,7,0};
void myfunction (void) {
    int i=1;
    int j=0;
    j=table[i]; // Will give you "2", not "3": indicies start at 0, not 1
    // Was that your question?
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 02-03-2005, 20:01
Rookie Year: 2000
Re: Look-Up Table
Yes, I believe that was my answer. I assume that I can delacre my array outside all functions and have it available everywhere too. My example would work in Basic(hopefully)
Unread 03-03-2005, 18:00
Rookie Year: 2000
Re: Look-Up Table
Is this the proper format then for a table:
rom const int table[5]={1,
2,
3,
4,
5};
Will the multiple lines confuse it?
Unread 03-03-2005, 18:19
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Look-Up Table
C compilers ignore whitespace, so you should be fine.
Lookup table generation tool WillyC Programming 12 15-02-2004 21:01
2-3 minute Interview at Pit Table ben_whly Chairman's Award 5 01-04-2002 16:00
table corruption... round 2 Brandon Martus Announcements 0 18-12-2001 23:57
table corruption Brandon Martus Announcements 2 20-11-2001 05:16
