Go to Post Something has gone awry this year in FIRST. I think more teams are concerned with winning and their robot that they don't even stop to think about the kids on their team, or the learning experiences of others. - Amanda Morrison [more]
Unread 03-03-2005, 18:01
Mumford 406 Mumford 406 is offline
AKA: Truth
#0406 (Mumford Magnums)
Mumford 406 is an unknown quantity at this point
Tilt Troubles
While our CAM will pan fairly well, the tilt is very erratic and has a great deal of delay.
Did anyone else have this problem?
Unread 07-03-2005, 14:49
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Tilt Troubles
We never tried using the tilt at all. Have you tried plugging the pan servo into the tilt pins and holding it sideways? Maybe its a defunct servo as opposed to defunct hardware.
Unread 29-03-2005, 21:12
dawonn's Avatar
dawonn dawonn is offline
Mentor
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Arrow Re: Tilt Troubles
WE had teh same thing, it apeared as if the tilt servo was programmed to move in incraments of 5 or somthing like that. Because of this erractic movment we could stop either 4 inches or 4f feet from the tetra during test.
too bad the camera got cut off the bot at the last minute.... i havn't looked at the camera since Feb 26, the camera's execution day. I can't wait to play with it again after the nationals though
Unread 29-03-2005, 21:45
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Tilt Troubles
For the off season trade up to CMUcam2 and use this bad boy.
http://www.roboticsconnection.com/ca...63/1194844.htm
But please note for legal competition use:
NOTE: FIRST ROBOTICS TEAMS - This turret only works with the CMUcam2 cameras purchasd from Seattle Robotics or Acroname!
We just learned that First Robotics is distributing a custom version of the CMUcam2 with their kits, which isn't compatible with this turret.
We are currently trying to obtain dimensions to determine if you can use the "Generic" turret version for these custom CMUcam2s.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 29-03-2005, 22:19
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Tilt Troubles
Elgin: It's not the mount.
Our camera does this as well, I think the reason being it doesn't try to keep the image in the center, but rather when it moves off its field of view it repositions the image to the center.
http://www.mikesorrenti.com/
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
Maxi Block Troubles MARobotics Electrical 3 27-01-2003 07:39
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
