Thread Tools |
Rating:
Display Modes |
Re: Cryptology
Ok, I'm giving up for the night because I don't feel like mucking around any more! I tried running a bunch of the words through something I wrote both forwards and backwards and both ways came up with a false answer (either some REALLY odd words or no word at all). If you want to see what I've made, check out http://www.mehh.net/phpstuff/compare.full.phps . You're not going to be able to run it on my server because it'd bog it down for hours with just one hit. If you want to play with it, you're going to have to bog down your own system
Just something like http://localhost/compare.full.php?0=buuconac&1=kgcuuwf will find words that will fit in both those letter patterns. You can add more (append &2=whatever and so on). Maybe I did something wrong, but I'm pretty sure it's working properly. Unless spaces and punctuation were substituted in this, I'm going to assume this is bogus. My dict is ~100,000 words and I'm pretty confident about my code.. so the fact that it returns nothing for me makes me question the validity of the crypt.(Couple notes about that PHP, it took almost 20 minutes to compare all the 2 and 3 letter words on my G4 1.25ghz. It'd be faster if you were using PHP5 and uncommented that first function. It'd be a lot faster if you rewrote it in C. It totally killed my p133.) Oh, and sample output is here: http://www.mehh.net/phpstuff/output.txt (from using: http://localhost/compare.full.php?0=...ul&3=fzq fgop) Last edited by evulish : 08-03-2005 at 04:41. |
Re: Cryptology
Well that makes the list of five vowels incorrect...u, r, n, q, o...sorry about that guys
However it is a fairly sure thing that u is a vowel which narrows the posted list to be match: deerhair (01123452) match: foothalt (01123452) match: footrest (01123452) match: keelhaul (01123452) match: rootfast (01123452) match: rootwalt (01123452) match: seedbird (01123452) match: woodbind (01123452) match: woodgeld (01123452) match: woodland (01123452) match: woodshed (01123452) match: woodyard (01123452) This would make either "n" or "a" a vowel in buuconac. |
Re: Cryptology
I'll double check the appropriateness of the message as well. Thanks again to those spending time on this! Last edited by Ein : 08-03-2005 at 20:07. |
