Re: Penalty for raising tetra higher than player station?
The refs never really acted on that "warning" friday morning concerning hassling of cappers in the end zones with teras above the horizontal plane of the plexiglass barrier protecting the operators. It never became an issue again however, which was definately good news.
Concerning what happened at VCU, we were in a practice match with team 401. While they were attempting to cap the center goal in the end zone, I turned to respond to our human player. An opposing team rammed into team 401 at that moment, causing the tetra to come off, falling directly at my head. I looked back in time to register it was there before the point crashed into my safety glasses. It pressed the safety glasses hard enough to cut into my forehead. I don't think I want to experience that again. But yes, FIRST definately has a reason to make us wear safety glasses behind the lexan, though I must congradulate 401 for their show of gracious professionalism, approaching me after the incident to make sure I was ok and apologize, even though it wasn't really their fault. Last edited by ShadowKnight : 06-03-2005 at 00:12. Reason: spelling |
I have to question why they dident do a overhang to protect the drives like they have in previous years. Anyone know why?
However, I agree with you that FIRST should take some action on this issue. It may be as simple as requiring hard hats, but a net or something might be even better. Until then teams should exercise caution when lifting tetras high near the players stations. Awareness of this issue could resolve it. |
fifty people a day walking in singin' a bar of Alice's Restaurant and walking out. And friends they may thinks it's a movement." It is a movement -- the head safety movement. We shall overcome. - Rick "Safety Zealot" Tyler Team 1294 |
geez... flying tetras.. |
In our first regional FLR the Martians hit us while capping a goal. The 3 tetra's came off our arm and fell over the payers station wall. I caught them and threw to the side of the field.
At our next regional GLR this penalty was announced by the head ref. and I asked what team would be disabled if a team holding tetras was pushed by another team and broke the plane of the players field. He said that the robot holding the tetras would be disabled. I disagree with his answer, when you are being pushed by another robot you have little control of your robot. I believe the team doing the pushing is the cause and if anyone is to be disabled it should be them. |
-Daniel |
You are pointing out a fundamental flaw in this whole ruling. There is no limit to how high you can raise a tetra and in order to cap the goals all the time (even if there are many tetras already on the goal). Your robot has to be able to raise the tetras higher then the height of the wall. Our robot raises the tetras straight up over the base of the robot, and the only way for us to get tetras to break the plain of the player’s station is if we are tipped by another robot. Thus our design is the safest out there and this safety problem still happened. This is one of those things that got missed in the design of the game, not that it is FISRT's fault. I think everyone would have missed it. But they should correct it by adding protection to the field no matter what it costs before someone gets seriously hurt. They could add lexan or netting over the players heads. It could be placed horizontally or vertically.
#10
We had a similar situation at UTC, luckily the refs let us play on. We had the arm extended 14 feet in the air and we got pushed into the other team's zone.. I'm not sure why we weren't disabled, maybe because the way we hold the tetra's they felt it wasn't going to fly off.
I know somebody mentioned the fact that some robots let go soon as the power is shut off, but if a team also needs to be under power to keep the arm up 2 things could happen. 1. the arm falls and comes back into the field NOT endangering anybody. Could that team be re-enabled if it's deemed to be safe again? (I'd assume no) 2. What if that arm falls and the tetra hits the top of the driver's station, the tetra could fly off and hurt somebody, wouldn't it be safer to just let the team keep playing? |
#11
Wetzel |
#13
Midwest Regional Finals
[I am currently watching some amazing robotics action thanks to Wildstang - Team 111 and NASA for providing the webcast to the Midwest Regional.]
Now to the subject at hand: I was, prior to the first match in the finals at the Midwest Regional, completely undecided on whether or not this rule is an appropriate way to fix the problem. I have come to the conclusion that this rule is ABSOLUTELY NOT an appropriate band-aid for the 'tetras-going-over-the-wall' problem. Here is what happened: One team on the blue alliance makes the very smart decision to go cap one of the corner goals in red alliance's home row, late in the match. As they are positioning to cap the goal, a blue alliance robot pushes them toward the goal and naturally, toward the wall. Of course, in order to cap the goal, the tetra must be HIGH. And, of course, once they were pushed, the tetra ended up over the wall. They were disabled with something like 10 or 15 seconds left. Thereby preventing them from capping the corner goal, taking away a row for red, and winning the match. Rather than having a penalty (in the form of disabling the robot) for play that should be perfectly allowable... MAKE THE WALL TALLER. -Andrew P.S. (Just my 2 cents) ![]() |
#14
Watching this thread, I have seen many suggestions about higher walls or nets over the top. Here is what I think about this: 1) If the game involves human players throwing things over the wall, neither a higher wall nor a net is practical. If one is used, the humans should have their own area and hard hats. 2) If the game does not involve throwing objects, a net that directs the objects to the ground in a certain area, like behind the player station, is probably the best choice. A higher wall will only block anything that is lower than its top.
3) Until FIRST decides to do something, which may not happen for who knows how long, just be careful. |
#15
In Chicago, the rule was "if you break the plane of the player station wall, you will be disabled." Did I miss something recently? Haven't seen that rule.
Unfortunately, we were disabled for this in an elimination match (along with our partners), and seeing it up close, I don't feel there was a safety issue, which I thought was the intent. The entire tetra was not over the wall (it was tilted downward into the field), and the only part that broke the plane (if that, it may not even have cleared the thickness of the wall) was the endcap, about 1/2" of it - 99% of the tetra was below the wall. I'm sorry, but I just don't agree with it. I do agree with possibly disabling if an entire tetra is dangling overhead (after they move away), but I don't agree with barely "breaking the plane" esp in the corner where there is no wall, and no people really in harm's way. In the corner area is a subjective call as to whether or not it broke the plane. But, it's now in the past.... |
| Player station question... | E Jones 234 | Rules/Strategy | 11 | 26-02-2005 02:37 |
| Regarding <G13> - placement of the tetra by the human player. | Leav | Rules/Strategy | 7 | 02-02-2005 10:26 |
| Tetra Loading Station | Dave Garnett | Rules/Strategy | 4 | 11-01-2005 16:29 |
| PDA's in the player station? | crispyc | Rules/Strategy | 10 | 17-02-2003 02:18 |
| Player Station Question... | archiver | 2000 | 1 | 23-06-2002 23:10 |
