Go to Post Our robotics lab has been closed for two days, TWO DAYS! :ahh: - Kevin Selavko [more]
Unread 06-03-2005, 00:37
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
Rookie Year: 2000
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
RoboEmu2 ERROR
The end result is that I am not getting my dll created.
I downloaded from http://www.mingw.org/download.shtml Current-->Bin-->MinGW3.1.0-1.exe.
I installed it to C:\MinGW\
I set the path in Autoexe.bat like so:set PATH=%path%;c:\MinGW\bin
I copied Makefile, re_compile.bat, re_core.c, re_core.h, re_hack.c, re_hack.h to my EmulatorSources director
I then put the default code(unmodified) into EmulatorSources.
I modified the necessary file as in the manual.
I double click re_compiler.bat
Dos pops up.
See the error in the uploaded pic.
It is a little cut off, but the cut off errors are similar to the visible ones.
I am running Windows 98.
I have gotten roboemu2 to work with its own dll
I quit FRC over 2 years ago (more if you're reading this past 2010).
error with adc.h incognito_NICK Programming 2 05-02-2005 23:27
MPLink Error cloudago Programming 2 01-02-2005 23:00
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
strange error Anthony Kesich Programming 2 25-02-2004 18:55
