Go to Post I am a human wiring diagram, how can i help you? - Jeffy [more]
View Poll Results: What type of drive train did you make? How many Speeds?
no wheels 2 1.31%
2 Wheels 17 11.11%
4 Wheels 48 31.37%
6 Wheels 56 36.60%
Tanks Tracks 17 11.11%
Multi-Driectional (omni Wheels) 20 13.07%
Crab/ Swivel Drive 14 9.15%
Walking 3 1.96%
1 speed 52 33.99%
2 speed 35 22.88%
> Than two speeds 17 11.11%
Something Else 12 7.84%
Multiple Choice Poll. Voters: 153. You may not vote on this poll
Unread 08-03-2005, 01:40
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
What type of drive train did you make this year?
I was wondering what types of drive trains were made this year?
Name:	Right front Drive Module.jpg
2004 - Drive Train- 2 Awards | 2005 - Drive Train/ Driver/ Team Captian - 3 Awards | 2006 - Mentor- 8 Awards
Unread 08-03-2005, 01:55
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
Re: What type of drive train did you make this year?
I lack the picture at the moment but I will find one soon.
We took your basic 4 wheel tank drive and tilted the wheels inward. Because that was unclear: we set the wheels so that the top of the wheels was closer to the center of the robot than the bottom of the wheels. The axles, motors, chains, sprockets, everything was mounted at this new angle. It actually was pretty easy to make and did not weigh anything extra. Usually the side of one tank drive is enclosed in a long thin rectangular box. We just tiled this box and mounted them against the angles we cut on the crosspieces that went across the front and back of the robot. (about 20 degrees for us). Putting the wheels like this also makes the robot very low to the ground.
This made the robot very hard to move off course. To help us maneuver more easily we placed two casters on the front of the robot. These casters were mounted to hinges. The hinges were positioned at 90 degree angles to the bar that made up the front of the robot. The casters were on the rotating flap of the hinges (on the underside) and on top sits an extruded Al stick. These sticks are connected by a pneumatic which is suspended in the air between them. When the pneumatic fires (parallel to the front of the frame) it presses the extruded Al pieces down which presses the hinges which rotate at a 90 degree angle to the frame and press the casters down.
Unread 08-03-2005, 06:32
JohnnyB's Avatar
JohnnyB JohnnyB is offline
JVN thinks I scream like a girl
AKA: John Barton
FRC #0217 (ThunderChickens)
Team Role: Operator
JohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of light
Send a message via AIM to JohnnyB
We (team 217) used a 6 wheel drive base runing off 2 Chip motors and 1 fisher price (per side). Lots of speed and pushing power, without having to shift gears.
I support the cloning of Paul Copioli
2005 ARCHIMEDES Division Champions
(muchos gracias to 245 and 766)
2005 National Championship Semi-Finalist
2005 Detroit Regional Champions
Unread 08-03-2005, 06:51
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We used a basic 2 wheel drive using the given transmissions in the rear and omni wheels in the front. It drives well and with 4 CIM motors has plenty of pushing power. The omni wheels allow for great turning and control it is a nice setup for our purposes.
Unread 08-03-2005, 08:34
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Basic 4 wheel drive (modified kit drivetrain), one speed, pneumatic tires.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 08-03-2005, 11:20
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
We used 1 CIM per side running in to a DeWALT transmissions driving 3 wheels on each side.
Unread 08-03-2005, 11:25
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
We built a 6 wheel drive train ruyn off of 2 CIMs per side through a custom one speed gearbox. We couldn't use the standard gearbox since we needed our CIMs to face eachother and have the output shaft go straight through. This shaft was then use to power a direct drive system. We used U-joints so our shafts could be at an angle so we could lower our center wheel by 1/32". The shaft then powered the wheels through custom-made miter gear-boxes.
It was a lot of work, but it has ended up being very effective. No chains to worry about throwing and noone has been able to push us. Even though we lost to them, in the final round, we pushed Adam-bots (245) all the way across the field with no problem.
I'll post pictures of our transmission later.
-Tony K
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 08-03-2005, 11:28
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Team Role: Coach
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
We used the kit transmission 4-wheel tank drive option with 48 tooth sprockets on 8.5 X 2 inch skyway beadlok wheels. Works really well!
Unread 08-03-2005, 16:09
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Talking Re: What type of drive train did you make this year?
omni BABY!!!
Unread 08-03-2005, 16:27
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
1 CIM & DeWALT transmission per side, each driving one 12.5" pneumatic wheel. Ball casters on the 4 corners. Manuevers well, but we could have used some more traction. Also got one of the ball castors hooked over the pipe on the base of a goal, and couldn't get back off.
Next year we're going to make the DeWALT's shift... I'm don't think I saw anyone else using the DeWALT transmissions at the Peachtree Regional.
Unread 08-03-2005, 16:38
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Front wheel drive, 2 powered wheels. On the back are dual tri-casters. Can't push anything, including a tetra. Only one speed.
Here are pictures of the drive train, wheels, and tri-casters.
Unread 08-03-2005, 16:43
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Tank treads, with a lowered idler wheel so that we can turn on a dime.
All of this powered by 4 speed automatic transmisson, which uses 4 Chips.
Unread 08-03-2005, 17:39
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
6 wheels driven by 2 chips put through the kit transmission. Its two speed shift on the fly though. By moving the transmissions left or right, using a pneumatic, we tighten a belt on one side of the transmission or the other. Different pulley ratios give us two different speeds. Nice simple 2 speed shift on the fly.
Team Website
Unread 08-03-2005, 17:43
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
for 1126 we had 6WD tank steering with a 4 speed transmission. it does great and it shifts automatically. it is simply amazing we also designed our own wheels. good luck every one!
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
  #15   Spotlight this post!
Unread 08-03-2005, 21:03
AJL930 AJL930 is offline
The one and only
#0930
Team Role: Mechanical
AJL930 will become famous soon enoughAJL930 will become famous soon enough
We used two drive wheels in the back powered by two chippy motors a piece and in the front we used two swivel casters.
Kit drive train question slickguy2007 Technical Discussion 8 03-02-2005 22:25
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
pic: Team 60 Drive Train Parts CD47-Bot Robot Showcase 17 07-02-2004 01:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Next year: Make the game understandable archiver 1999 23 23-06-2002 22:53
