Go to Post The part I like best is your method of transfering the torque via the balls. Very elegant. - Joe Johnson [more]
Unread 11-03-2005, 22:17
locohammerhead locohammerhead is offline
locohammerhead is an unknown quantity at this point
is it possable to get a joystick with a gameport
is it possible to get a joystick with a game port that will work with this years interface that isn't the one they give us in the kit. I'm looking for a joystick that is stiffer then the one they give us and sturdier. I noticed the hot team at this years eastern Michigan regional competition and they had a steering wheel for their robot. I don't know what they used but if anybody from that team sees this post by the end of the regional please come over to team 1256 and help us out with how to get a joystick that will possible work but if you don't see the post in time please post the answer here. I would really like to get a joystick that might work. and when are they going to update the interface to USB or fire-wire something good not out dated. I mean i know they are making a good amount of money off of these controllers but we pay a ton of money to get the kit and the best they can give us for controllers are the ones that cost them less then 5 dollars. If you ask me but that is sad. But that would be great if you could help us out with that. By the way if you do see this my name is Brandon Cook just ask for me and i will come and talk with you and my other driver who will talk for me because i have lost my voice.
Thanks a lot,
Brandon Cook
and sorry about the awful spelling
Last edited by Josh Hambright : 22-03-2005 at 02:23. Reason: No need to apologize, just use the 'check spelling button' - spelling checked and corrected.
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
