A Warning to Human Players During Autonomous
Human Players should stand firmly on their pressure pads and avoid shifting their weight during Autonomous Mode. Any movement could cause the pressure pad to switch off and disable your robot. This could have disastrous effects on your autonomous routine. To test what actions will turn your pressure pad off, watch your green light on the end of the alliance station and shift your weight to see if it turns off.
My team has a very consistent autonomous routine that we ran in every match at the Pittsburg Regional. We did not change this routine on Friday or Saturday of the competition. During a few matches, our autonomous routine stopped half way through the routine and our robot was disabled (indicated by a solid disabled LED on OI). We talked to the IFI guy about this and he suspected our OI might be faulty. We decided we would replace it if we ever had the problem again. We did have the problem again in the second quarterfinal match. This time the robot stopped half way through the routine and started running a different routine that got our robot stuck in a goal. Luckily, 869 and 808 won the match for our alliance so we had had time before the semifinals to diagnose the problem. Our autonomous routine is selected by rotary (analog) switches. The routine that ran our bot into the goal in the second half of the autonomous period is the same routine that would run if our rotary switches were set to 127 and 127 (Note: during the autonomous period, the OI transmits 127's for all analog values and 0's for all digital values). It seems the robot got temporarily disabled and read in 127's into the autonomous selection variables, then ran that routine when it reentered autonomous mode. This leads me to this warning for programmers: If you use switches on the OI to set autonomous routines, make sure the all 127's or all 0's routine is a "do nothing" routine. We borrowed an OI from Spare Parts and swapped it with our OI. While we were queuing up for our next match, the IFI guy told us that he thought that our pressure pad might be responsible for the disabling. This makes sense because our human player is very light and might lean toward the field to watch our autonomous routine (especially the "tetra catching" part that is always entertaining). Before the next match, we tested this by watching the green light on the end of the alliance station that indicates the state of the pressure pad (“on” indicates a human player is on the pad). Sure enough, if our human player stood on the pad and leaned toward the field, the light would turn off. We didn't have this problem again, so I pretty sure that this human player/pressure pad interaction is the cause of our problem. It could have been a faulty OI, since we did change the OI, but that seems unlikely. We will reuse the old suspect OI in future competitions (the other OI was a loaner). So please warn all human players and programmers out there about this potential problem. |
Re: A Warning to Human Players During Autonomous
Thanks for the heads up!
I'll pass that along to our programmer. I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something. -Andy A. |
Also keep in mind that there is a penalty if you leave the pad during autonomous. I did some testing of my own at UTC in the matches that I human played, and I found, even with one foot in and one foot out of the pressure pad, the green light was still lit. Thus, I got the impression that they were more forgiving than what has been described here. Anyone else notice how much pressure was needed to power on the pressure pads?
dont jump up and down in your excitment :^)
Wetzel |
Human players are also not allowed to touch/grasp/hold a tetra in anyway until the autonomous period has ended.
once at the Sac regional one humal player was running back to the pad and he tripped so as he fell he kinda launched himself at his pad and barly got his hand on it, but it didnt register, it sure was a valient effort though.
It is interesting that the human player on the pad can communicate with the robot by shifting his/her weight on the pad. I am sure that FIRST did not intend this. We use a set of switches on the robot to select the autonomous mode in binary. Values set by these switches are not affected by the disabled state... |
#10
Code:
if(!autonomous_mode){
//set auto select variables
I personally would prefer to just cut bait and sit out the rest of the 15 sec with a "do nothing routine", than risk getting stuck in a goal again. We were lucky to win that quarter final match. We were stuck for nearly the entire match and committed a 10 point penalty, but 869 and 808 overcame all that and won it for the alliance. |
#11
pad change the autonomous program that is selected after the match starts? |
#12
We never had a problem with the pressure pad or our human player on the pressure pad, although we didn't have any purposeful auton modes except go to the human loading zone and fun acress the field into other bots
but besides that, the pressure pad fine, we never once lost power to our bot, although an OI at the competiton did give us problems in one of the stations... that's another story... Also be careful to not touch any tetras until the auton period is over, that is when the signal goes off and not when the clock resets to 120. Our human player grabbed a tetra when the clock hit 120 seconds after the 15 second auton, but the signal did not go off until 119 seconds left, with that we got one 10 point penalty for touching a tetra while in auton mode. So my warning to all teams is to not touch tetras until the buzzer goes off and the drivers are able to step forward and drive their bots. Penalties are bad, don't get hit with them for things like that. |
#13
We had this problem and I am trying to warn others about this potential problem. It was a very frustrating problem to diagnose, especially since you can't simulate the controllers and pressure pads on the field with a simple dongle box (it still sends OI data in autonomous, so you could even drive the robot with a joystick if you wanted). If everyone is aware of this potential problem, it doesn't take much to prevent it from ever happening again. |
#14
Is there a weight requirement for the pressure pads to remain active?
#15
i dont know how much wieght you need. all our HPs are 150+ pounds
| Are you planning to use your Human Players? | Swampdude | Rules/Strategy | 23 | 09-02-2005 19:37 |
| Traits of the Drivers, Coaches, and Human Players | mhayon | General Forum | 34 | 08-02-2005 09:26 |
| [FVG]: Human Players - All AI? | Mike Ciance | FIRST-related Organizations | 4 | 05-07-2004 20:38 |
| [FVG]: Human Players | Mike Ciance | FIRST-related Organizations | 6 | 21-06-2004 21:34 |
