Go to Post So go out and start thinking outside of the KOP. - ChrisH [more]
Unread 15-03-2005, 00:17
robotaddict's Avatar
robotaddict robotaddict is offline
FRC #1294 (Screws Loose (hopefully going to be changed soon))
robotaddict is on a distinguished road
Holonomic Drive Mathmatics Discussion
Have we all heard of holomonic drives here? If not let me expound... A holomonic drive uses things called "omniwheels" which are sort of like normal wheels, but with rollers mounted along the wheel which allow it to move perpendicular to the plane of the wheel. If you mount four of these with one pair perpendicular to the other. This allows motion in any direction from any starting position.
Now comes the interesting part, how on earth do you control this darn thing?! Sure you can move in any direction, but this would confuse any mortal driver. So I had the "brilliant" idea of using a gyro to give the robot absolute direction, that is when you push the stick away and it goes away, and vice versa, but in uncomplicating the drivers' job I have complicated my own. Now not only must the joystick inputs be scaled and realigned, but now they must be modified by the gyro's output, too. Oi. So here are some rudimentary equations...
true y input = (cos(angle from origin) * original y input) + (sin(angle from origin + 90) * original x input)
true x input = (cos(angle from origin + 90) * original x input) + (sin(angle from origin) * original y input)
You can see my dillema, especially after you add the z axis, though it should be a good deal simpler... PLEASE ADVISE!
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
check out this lego Holonomic drive base Tytus Gerrish Technical Discussion 10 15-08-2004 17:47
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
