Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Unread 15-03-2005, 14:01
Arc736UV Arc736UV is offline
Arc736UV is an unknown quantity at this point
CMU Cam GUI
everything was followed in the user manual for the cmu cam setup but when the gui is started an errror message pops up saying "error reading file config.txt" and then it ask for port and after that nothing works in the gui.any advice?<were pretty sure that the hardware is setup right>
The *BIG* CMU Howto pi_guy578 Programming 17 21-12-2005 13:24
Grid on CMU Cam Java GUI Leav Programming 0 14-02-2005 17:06
CMU Cam servo jitter adamdb Programming 3 01-02-2005 14:42
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
