Go to Post It all seems like good clean fun until someone drops a Phaeton 65 meters. - Rick TYler [more]
Unread 19-03-2005, 21:18
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
K.I.S.S. in action
We have all heard it, K.I.S.S, Keep It Simple Stupid. We may say we try to apply it, but do we?
I just got back from the Chesapeake Regional, our first one this year. I would be sleeping, but I'm amped up on energy drink because I couldn't fall asleep on the bus, or face great personal risk . We managed to rank 15th out of 55 or so. An improvement over last years 25th out of around 55, and the year before that (our rookie year) we placed 50 or so out of around 55. I'm happy with that.
Now back to KISS. This year out bot was a 3"x2" rectangular aluminum tubing frame, 1/4" wall. We used the kit drivetrain converted to 4wd, the trannies mounted on top of the frame. In the front we had 2 vertical 2x2 1/8"wall aluminum tubing members, and a 1.5x2 1/8" wall aluminum arm. We drove the arm with a sprocket bolted to it, and the bottom sprocket had a 5:1 gear down to a van door motor with spur gears. we had our electronics board in the middle of the frame, and lexan covers on the top and sides. For a hook I welded up a hook that reminds me of a jailai (sp? pronounced "hi lie") racket/scoop thing. We put it on a spring loaded hinge so that when we pushed down on the stack of tetras, it folded out of the way. That is pretty much it for our robot. Very simple, no telescoping or cascading lifts, no pneumatics, no cable systems.
We found it to be a very robust machine. We even nicknamed the the front of out machine "The Ramminator" since it was so solid. We never got called for ramming, because we didn't, we would slow down and then shove... just a fun name for it.
I find it very interesting that with a machine that simple we managed to rank 15th. We had a bad first 2 seeding matches, but then we were on fire for the other 3 on Friday, it was awesome. Today, our teammates wanted us to be defense, but our opponents weren't that aggressive, so most of the time it looked like we were just driving around looking like idiots. In our last match, we finally were offensive, but we lost the match. Our one ally got stuck for a little bit, and our other one was a box-bot (don't even get me started on those...) So between us looking stupid today, and us being a quiet team, no fancy outfits or mascots, we didn't get picked for an alliance. But we were the first backup team.
We could get 3 tetras on the center goals, and 6 on the side goals, about as much as some of the teams with fancy arms. But we were extremely stable too. The only way we would rock is forward, and then unless we got the front all the way down, we would self rite without driver/arm operator intervention. Handy? I think so.
Now KISS, doesn't have to mean no pneumatics, no cascading lifts...etc. You just have to use them well. Another excellent example of KISS would be team 1027. (I hope I'm remembering that right... I think I am) They had a low sitting bot with a telescoping arm, and pneumatics to raise and lower it. But they had a fixed end on their arm. Very effective, very fast, and very clean caps. Many kudos to them.
Now in Philly, since we know the game, and that defense doesn't work for us, its time to kick some tail.
Any other teams have a simple design that performed well?
Unread 19-03-2005, 21:29
psquared89's Avatar
psquared89 psquared89 is offline
AKA: Pat Pannuto
FRC #0245 (Adambots)
Team Role: Driver
psquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the rough
Re: K.I.S.S. in action
Preform well? Try winning two regionals, so far...
Our team (245) is extremely simple. Kit base and trannies (only 1 chip each, for weight), a high-low in the front, and a "self-centering" poker on the end. Self centering means a piece of PVC pipe with a spring on each side. The only mildly complex thing are a pair of "feet" in the front of the robot, but still very basic, pneumatics drive a nylon pad to the ground in front of our robot.
Our simple design has won two regionals so far, Sacramento where we were seeded 5th and became the 3rd place alliance captains, thanks to teams 766 and 1072 there. We also won Detroit a few hours ago where we were seeded, thereby we were the 1st place alliance captains again. Thanks here to teams 217 and 301.
The real reason simple wins is this, our base moved by about halfway through week 2, we were capping tetras by the end of week 4 (not to say we didn't work on after this, but...). I saw this especially when I visited Great Lakes for finals, there were a large number of amazing robots mechanically, but their drivers needed a lot of practice. Last year's game really tested human player ability, this year, it tests driver skill.
In two weeks we're going to Grand Rapids, we'll see you all there, and the next stop is Atlanta. Good Luck everyone and remember, K.I.S.S.
At the end of the game, the King and the Pawn both go back into the same box.
~ Italian Proverb
adambots.com
Unread 19-03-2005, 21:41
Meyerman Meyerman is offline
Meyers #37, Pink Petunia's!
AKA: Meyers
FRC #0056 (RoBBE Xtreme)
Rookie Year: 2000
Meyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to behold
Send a message via AIM to Meyerman Send a message via Yahoo to Meyerman
team 56 has a simple design but is very effective we used 80/20 for a chain driven sliding elevator that has a fixed angle. the tetra holder is pretty much a bent piece of electrical conduit but the way it braces itself makes it very effective. we have won 2 design awards so far and got finalist in the nj regional , first seed in nj, and 4th seed in sacramento, looking foward to see how our simple design works out at the philadelphia regional.
Unread 19-03-2005, 21:43
t0ny127's Avatar
t0ny127 t0ny127 is offline
t0ny
None #0056 (Robbe Xtreme)
t0ny127 is a name known to allt0ny127 is a name known to allt0ny127 is a name known to allt0ny127 is a name known to allt0ny127 is a name known to allt0ny127 is a name known to all
Send a message via AIM to t0ny127
Also we used a 4 wheel drive system with a shortened wheel base, using the stock gearboxes that we were provided with. This bot is very manuverable and functional, yet simple at the same time.
Robot building is over. I build cars now.
Unread 19-03-2005, 22:06
Team Alumni
I'll look forward to seeing you there. Maybe we can make an alliance of simple design robots, and show the teams with the over-engineered bots how to do it
Unread 19-03-2005, 23:18
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Let's take a look at team 33 for a second....
Great Lakes:
-Active tetra manipulator that gripped at the apex of the tetra and stored up to 4 in the robot.
-Crab drive that didn't have the kinks worked out
Seeded in the mid 20s, were not picked.
Detroit:
-Replaced the active tetra grabber with a "pitchfork". They can no longer store tetras in the robot (because the new design can't get them out) and they now score one at a time
-Crab modules were swapped for standard single speed skid steer modules
Seeded 8th, were picked second, and were regional finalists.
From what I've seen, simple is MUCH better this year, and whatever design enables sheer stacking speed is the best (fancy grippers that take a long time to get lined up aren't worth the extra time).
-Paul
Unread 23-03-2005, 13:05
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
CONGRATS BEES!!! !
yes i agree.. simple best..
look at our bot. .www.instigators1596.com... its pretty simple and straightforward. .. (we have cables inside the arm thats a little tricky .. but still simple.).. standard transmissions no pneumatics, 4 wheel drive, basic telescoping boom.. . during the test day and for the first 3 rounds of GLR we had almost nothing to do in pits, just tighten bolts. . touch ups. . etc.. then our wire broke due to a wreckless driver move (we had two sets and now we only use set 1...).. other then that .
we are regional (rookie of the year) so we are also going to Atlanta.. we seeded 12th, and were the 8th (picker) for alliances . .we made it to semi finals..
2005 GLR: 12th/58 Seed, Aliance: 1596, 910, 1447 (Semi Finalists) Website, Rookie All Star, Highest Rookie Seed, and 2 Peer Awards, my BIG thank you thread, PLEASE READ
2005 GTR: 11th/66 Seed, Aliance: 703, 1596, 1680 (Semi Finalists) Highest Rookie Seed & 1 Peer Awards
2005 Championship (Galileo): 36th/86 Seed Highest Galileo Match Score: 123:7 Thanks 447 and 121
2006 Website (Totally Revamped):Instigators1596.com
2006 GLR: 31st/61 Seed, Aliance: 835, 1213, 1596 (Quarter Finalists) Spirit & 3 peer awards, THX!
2006 Waterloo: 7th/31 Seed, Aliance: 1219, 1596, 912 (Semi Finalists) Spirit & 2 peer awards, THX!
2006 Waterloo: Aliance: 1596, 1680, 1114 Higest Match Score: (Q22) 128|32
Unread 23-03-2005, 14:15
Squeaky Squeaky is offline
AKA: Travis VanSchoyck
FRC #0401 (Hokie GUARD)
Squeaky is an unknown quantity at this point
Send a message via AIM to Squeaky
Well I agree that 'KISS' seems like it works the best when it comes down to winning the competitions, but what is better than seeing a robot that stands out because of some incredible design. When your robot becomes more complicated, there are more things that can go wrong, but usually the more complicated design has a purpose. My team won a design award this year at VCU because we had a 192-tooth, 24 inch diameter, sprocket that acted like a turret so that our arm could rotate 360 degrees. We made this sprocket ourself with a sheet of aluminum, a hammer and a punch, and a couple ours over the drill press. No it wasn't a simple design, but we never had one problem out of it. My favorite part about attending FIRST competitions is seeing the crazy unique designs that teams come up with, not seeing who wins.
And our 'not so simple design' helped us win the regional, so we must've done something right...
Team 401 - Hokie GUARD
2005 VCU Regional Champions with 435 and 122
2005 VCU Motorola Quality Design Award Winner with our "Creative Turret Design"
2004 VCU Semifinalist
Unread 27-03-2005, 11:51
AKA: Meyers
Rookie Year: 2000
well our simple yet very effective design came through we won the Philadelphia Regional with our simple bot and the help of our partners 365 and 316. hopefully you will all be able to see it at nationals now. our students are taking on a not soo simple task we are going to try to fundraise all the money for nationals now. wish us luck and if you can help us out please send me a private message.
Unread 27-03-2005, 19:42
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Our design was incredibly simple. Two bars for height, the arm(a 2' 8'' stick of the same kind of metal as the rest covered in padding) mounted on the front one on a hinge so it would fold up for the dimension restrictions, the back bar is stationary, and the front bar moves up, operated by a winch system. Our base had a pretty thick shell, which made it bottom-heavy and not at all tippy.
We couldn't stack on the center, but we could stack two high on the smaller ones with no trouble, and we could push other bots around, though we only got to try that once.
We were at Chesapeake too, and we were picked by team 614 along with 339(thanks guys!!!) for the finals. We wound up 29th out of 55. We're also a rookie team.
We're changing our motto next year to be "servo es simplex", which is Latin for "keep it simple." We would have had "servo es simplex bardus"(keep it simple stupid), but our head mentor cut it short...
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 27-03-2005, 19:51
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We won FLR with a very simple design. It's the best policy to keep everything in front of you. The more complicated you make it. The more things on the robot that can break.
Unread 28-03-2005, 12:45
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Team 40's robot seems pretty simple to me. It is simply an aluminum ball on the end of an arm that telescopes and rotates on a shoulder. Its very simple, yet very effective, just drive up to the auto loader and get the ball somewhere inside the tetra, the lift the arm and you have one tetra perfectly placed and ready for delivery. Oddly enough, we got the Driving Tommorow's Technology Award for putting a ball on the end of an arm
From what I've seen, it seems that the simpler the design, it more effective a robot is, at least this year.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
[694] Simplicity in Action: Drivetrain & Other Systems Pics and Video Ianworld Robot Showcase 2 19-02-2005 08:48
IEEE: A Call to Action from Dean Kamen Erin Rapacki General Forum 25 09-06-2004 20:37
Using an action register? blueWarrior General Forum 4 14-10-2003 21:07
Live Action Video - 3D Animation Combination Ryan Dognaux 3D Animation and Competition 18 06-08-2003 19:33
Battlebots Action Figures Madison Chit-Chat 29 19-08-2001 20:27
