Go to Post It will mean far more than you can imagine...and really, you can't lose. - David Kelso [more]
Unread 19-03-2005, 23:35
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Interesting belt problem
Hey there everyone, I have an interesting little problem maybe someone has encountered before.
First, as a reference photo so that maybe everyone will know what I am talking about check this:
or perhaps you were lucky enough to see the gearbox in person in Phoenix
Anyway, here is the problem:
As you can see from the photo our setup uses the stock gearbox and CIMs leading to our "shifter transmission" which has three speeds, and for this we are using a trapezoidal tooth conveyor belt (makes it easy to push with a pneumatic cylinder). During testing, we put two Goodyear belts, I'm not sure of the size but I am fairly sure they were 3/8" belts made of rubber with Kevlar. These belts lasted us for almost two weeks of testing on various surfaces, concrete and carpet etc. without breaking or wearing the teeth off. These belts we ordered from MSC I believe.
Finally, a few days before ship date (of course), the belts snapped, so we replaced them with what we thought were the same belts from the catalog. They came from a different order because we wanted to make sure this thing worked before we made a final decision. These belts wore down within a day. We ordered them from the same catalog and whatnot, I think the only difference we could see on the belts was the different lot number. We snapped all of these before ship date so we tried some different belts made of neoprene and polyester I believe, from McMaster. We've had moderate success with these but they still don't last as long as the original belts. We've noticed some shredded teeth and needed to change them out a few times after several matches.
Because it is a reliability issue (the belts take about 5-10 minutes to replace, time you don't have in the semis or finals), and we honestly haven't shifted that much except to get back behind the line at the end of a match or two, we have discussed taking off the shifter box and just using stock gearbox perhaps with some different sized sprockets. This would give us the weight for better lexan, and a few cool features we have had to omit
My questions are: What do you think about those belts? Was it a bad lot? Nothing changed between the replacement of the original belts. We have felt for sharp edges and whatnot. I have looked for some easily replaceable alternative, like belt we could crimp on, instead of having to take apart the transmissions to slide the belt loop on, but haven't found anything affordable that I think would work. Does anyone know if such a thing exists?
The team has pretty much decided that on Thursday in Vegas they will try going stock and see how it performs. If there are no major drawbacks that is fine, plus it leaves weight for cameras and claws and lights and other goodies I guess another question I have is how often people are shifting that have the ability to.
Anyway, any help/comments/chit-chat is appreciated as always And if anyone has any questions about anything I described you can post them or PM me.
Oh, and I apologize for my apparent lack of knowledge on the specific parts we ordered and whatnot, I didn't really help much with this design/implementation but I will be contacting someone from the team who knows a little more about it than me this weekend.
Thanks
-Steve
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
