I was just preparing a Purchase order via the IFIrobotics site for a summer project to make a running plateform using the kitbot chassis/tranmissions/CIM motors.
Alas, they are out of stock on the motors and won't be restocking. Anybody know of a source for these motors? ![]() |
Re: CIM-MOTOR source
IFI is the only source for those and you are correct in saying they will not be stocking any more. Try trading with another team like through the CD swap system.
Can somebody refresh my memory as the current bot is waiting for us in Houston? Does this year's CIM motor have the same output shaft as either or both of the last two year's? If so then I can get by with gutting old machines. I've sent a request into the CIM folks via their website. I'll post here if I get any response.
The keyway shouldn't be a problem. Our practice bot is using old CIMs with the kit transmission. just make sure you put the 3 nilon washers before you put the key in, and get the right set screws (dont stick out of the hub) and put some red locktide on them and you should be set.
Dave |
if anyone can find a source for cim motors before the summer that would be awesome
please pm me |
or you could post it here so that everyone could benefit ![]() |
| No CIM Motor in 2006? | Sscamatt | Rumor Mill | 21 | 22-03-2005 22:47 |
| Allowed to use CIM motors from last year? | lphan | Motors | 7 | 26-02-2005 16:49 |
| CIM speed in reverse? | colt527 | Motors | 41 | 06-12-2004 19:09 |
| CIM Motors to pull up Robot | Joe P | Motors | 7 | 11-01-2004 22:27 |
| CIM vs. Drill motor | duckshepherd | Motors | 3 | 15-02-2003 18:36 |
