Go to Post It takes a special kind of lunatic to be the school sponsor/mentor for an FRC team; when you get one be thankful. - Fusion_Clint [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 27-03-2005, 23:30
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
A Webmaster's Options
I was recently added to the list of fine people on team 360. My job is to take over the website because the current webmaster is leaving next year. I have decided that instead of making a layout and editing the pages by myself, I'm going to use a CMS of some sort. What it boils down to is this: PHP-Nuke, vBulletin, or write my own with PHP and MySQL.
What do you all suggest from these 3 options? Also, what is the portal addon that these forums run for vBulletin? Does anyone have suggestions/recommendations for vBulletin themes or addons? Thanks for your help.
Unread 27-03-2005, 23:33
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: A Webmaster's Options
I'd avoid PHP-Nuke for sure. Look at PostNuke (don't be put off by there bad website, it's a pretty decent system) or Drupal.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 27-03-2005, 23:34
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
I'd personally write my own becuase I feel that items like PHP-Nuke are over used. You can also add your own creativitey (Which is what FIRST Recongnizes) if you make it yourself. You also have a bigger feeling of pride knowing you made it yourself.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 27-03-2005, 23:43
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
I agree, in some respects, you still can have a great deal of creativity with a cms that is already made, especially if you make your own themes and modules...
...but it is not as fun, so I would recommend that you build your own, like I did for my personal website.
- from B B frank
Unread 27-03-2005, 23:46
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
I will personally suggest Mambo, which I used for my team's website. (http://www.dublinrobotics.com ) It has a bit of a learning curve, but once you get the hang of it, it is very flexible and there is quite a bit of community support for it.
When I was getting ready to redesign our website, I debated writing my own PHP/MySQL system as well, but decided against it. Perhaps the main reason I decided against it was the fact that I am a senior this year and will not be around next year to help out with the site should anything go wrong or if they want to add on to it. This is the main concern you should look at when deciding what to do. How easy will it be for my team to use and update the website without my assistance?
Just remember that there is not a one size fits all answer. Pick what you think will work best for your team, not necessarily what others suggest. Your website should be a method for your team to communicate, not just another thing to do for an award.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 28-03-2005, 00:03
plutonium83
Posts: n/a
I'd say start on content before you even think about a new spiffy cms.
Unread 28-03-2005, 01:03
JohnC's Avatar
Wow. Thanks for all the suggestions. I've been researching all kinds of different CMSs this weekend and I still haven't found some of the ones you suggested. I decided that if none of the suggested ones particularly suit my fancy, I'm going to use PHP-Nuke because I just realized it has phpBB built in with perfect compliance to whatever theme you may be using. It's amazing. So tomorrow I'll be looking all those suggested systems over. Thanks again!
Unread 28-03-2005, 06:49
JonBell JonBell is offline
None #0546 (Technotics)
JonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really nice
Send a message via AIM to JonBell
Don't forget Mambo. I just set it up on Team 546 - Technotics' website. I'm yet to add much content (probably won't until next year), but it's very easy to and very nice looking.
Unread 28-03-2005, 21:13
JohnC's Avatar
Does anyone know what portal addon and/or skin is used on this site?
New Batteries, New Segways, New Options, Oh my! Joe Matt Dean Kamen's Inventions 14 15-03-2005 19:16
A question about control system options computhief263 Control System 7 04-02-2004 14:46
Attention all Webmasters out there.... Meyer_Shuky Website Design/Showcase 46 12-01-2004 16:53
Team Role options Brandon Martus Announcements 11 29-05-2002 21:35
Funding Options for 2002 Jeff Waegelin General Forum 3 15-10-2001 01:30
