Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 28-03-2005, 12:43
larwilliams larwilliams is offline
larwilliams is an unknown quantity at this point
Determining Team Color
Hi,
I tried searching for this in the forums so please excuse me if I simply missed it...
Is there any way to determine programmatically which team color you are assigned? This is for autonomous mode programming...mirrored on opposite side of playing field.
Thanks. Larry
Unread 28-03-2005, 12:58
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Determining Team Color
Not sure about that but another way you can get around this is to wire up a switch to the Robot Controller to correspond to which side your robot is on.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 28-03-2005, 13:15
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
No. The team/alliance color is not accessable from your program.
We too use a red/blue switch of our own that the coach or driver sets before the start of the match.
Unread 28-03-2005, 13:47
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
An easy way to set team color without adding any switches to your bot is to use the wheel on the older flight stick joysticks if you are using those. The wheel isnt used for any normal robot control, so you can say turn it all the way forward for blue, and all the way backward for red. Then, in your code say:
Code:
if(p1_wheel > 210) color = blue;
else color=red;
In this the color would default to red, unless the wheel was turned towards the front.
Unread 30-03-2005, 07:41
Thanks to all that have responded.
It seems that a simple toggle switch is the way to go to set team color for programming purposes. We already have a 3 position switch that we are using to specify left, center, right starting position for autonomous mode...
Larry
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Representing your team? LauraN General Forum 10 18-04-2004 15:59
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 09-04-2004 21:12
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
