Go to Post At the end of the day, and this is where many may disagree, it's about what is learnt and not about who wins. - popnbrown [more]
Unread 30-03-2005, 10:28
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
Rookie Year: 2000
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
Java headache problem
I am having problems with this program any help would be much appreciated:
Write a program named SellStocks that calculates the value of a stock sale. The user will be asked to enter the stock price, the number of shares to be sold, and the commission rate. The program will calculate the value of the shares by multiplying the stock price by the number of shares. It will also calculate the commission (the value of the shares multiplied by the commission rate) and the net proceeds (the value of the shares minus the commission). The following example shows what the user will see on the output command prompt.
This program calculates the net proceeds from a sale of stock.
Enter stock price: 10.125
Enter number of shares: .11
Value of shares: $111.38
Enter commission rate (as a percentage): 1.5
Commission: $1.67
Net proceeds: $109.71
I would post my program for you to decipher but at last compilation it had 31 errors so it is best to just treat it as a blank slate :0
Unread 30-03-2005, 10:36
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Java headache problem
Well... dern. You want it in Java? Ya sure about that? I could do it in seconds in C, C++, or PHP...
So, I'll just say "Could I see the source code please?" and hope I can spot the error(s) there.
Unread 30-03-2005, 10:51
MisterX's Avatar
Alumni
AKA: Mr. X
FRC #0521
Rookie Year: 2000
feast your eyes on 31 errors of pure Java!
File 1:
public class SellStock
public SellStock()
price = 0;
numbers = 0;
value = 0;
commission = 0;
rate = 0;
proceeds = 0;
public void addPrice(double count)
price = price + count;
public void addNumbers(int count)
numbers = numbers + count;
public void addRate(double count)
rate = rate + count;
public void addValue()
value = price * numbers
public void addCommission (double rate)
commission = value * (rate/100);
public double getProceeds()
return value - commission;
File 2:
public class SellStockTest
public static void main(String[] args)
SellStock iSellStock = new SellStock();
iSellStock.addPrice(10.125);
iSellStock.addNumbers(11);
iSellStock.addCommission(1.5);
double totalValue = iSellStock.getProceeds();
System.out.print("This program calculates the net proceeds from a sale of stock to be:");
System.out.println(getProceeds);
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
If you can do it in seconds with C++, theres NO reason you cant do it equally as fast in Java.
I'll say the same thing: source code would be tres easier for us.
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Unread 30-03-2005, 10:52
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Don't just treat it as a blank slate because you have 31 errors, have had programs that had many errors that have been caused by small little errors, like forgetting to define a constant or including a library.
It is also a good idea to learn from your mistakes, so you do not make the same mistakes again..
If you post the code, I am sure someone would be able to spot the errors within just a small amount of time.
EDIT: I see you posted the code while I was typing.
- from B B frank
Unread 30-03-2005, 10:58
dm0ney's Avatar
AKA: Deepak Mishra
public SellStock()
price = 0;
numbers = 0;
value = 0;
commission = 0;
rate = 0;
proceeds = 0;
SellStock should not be a public class, only class. You cannot have two public classes declared in the same file.
Next, missing a semicolon on in the addValue() function.
Finally, getProceeds in println is a function so getProceeds()
I'll check for logic errors next, but those are the syntax.
Hope that helps.
Going on to some logic / style issues.
Firstly, dont always name variables count. Good practices mean using descriptive variables, also in Java, set and get are the terms used in code, not usually add.
The program was meant to take input from a terminal window according to the description, are you just testing the class itself before implementing a user input?
Alumni
Unread 30-03-2005, 11:02
MisterX's Avatar
Alumni
AKA: Mr. X
FRC #0521
Rookie Year: 2000
Hope that helps.
yeah thanks alreayd better off then when I started. Sorry I didnt make my self clear before that is two seperate files, 1 is for the actual calculations then the second is where I put in the data to compute and print out.
Unread 30-03-2005, 11:08
AIBob's Avatar
AI Programmer
double price;
double numbers;
double value;
double commission;
double rate;
double proceeds;
public SellStock()
//these variables need to be.
price = 0;
numbers = 0;
value = 0;
commission = 0;
rate = 0;
proceeds = 0;
value = price * numbers; //don't miss semi-colons
public
class SellStockTest
System.out.println(totalValue/*getProceeds*/);
Those are the only errors that were found with the compiler I used...
Hope its better
- from B B frank
Unread 30-03-2005, 11:09
dm0ney's Avatar
AKA: Deepak Mishra
Code:
//Declares, Instantiates new SellStock class
//Price of stock
//Number of stock
//Calculate Value of Stock!
    iSellStock.addValue();
//Add commission owed from stock sales, Calculates
//Not sure what you wanted here?
//Print out statements
//This could either be as follows or you could printout totalValue since you declared it above.
System.out.println(iSellStock.getProceeds());
EDIT: must declare variables like AIBOB above said. I did that and forgot to forward that on to you.
This is an edited version of the last class. You never calculated the value of the stock, so it would output zero. I added your function call to calculate Value (addValue()) and to my knowledge it works in that implementation.
Might I suggest using setValue, setXXXX, getXXXX for variables. The addXXXX gets confusing. Also change the counts to something even iXXXX where X is the variable and set price = iPrice.
Hope that helps, Good Luck.
Alumni
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Java Books Yan Wang Programming 1 27-12-2002 16:26
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
