Go to Post Batteries don't help you if they're lying on the field. - Kevin Sevcik [more]
Unread 08-04-2005, 15:04
Plloyd Plloyd is offline
Plloyd is an unknown quantity at this point
Intermittent Code Error
Every once in a while, (0-1 times per match) our robot disables itself and the code error light comes on... requiring the drivers to push robot reset to clear the error and continue playing. This has happened on more than one RC, so it probably is a problem with the code.
Now... this happened at a regional and the IFI representative there informed me that his scanner picked up an "Invalid CONTROL or CURRENT_MODE byte" error.
Looking at the code... the control and current_mode bytes are the last two bytes of txdata. However, I am not using them in the code at all... nor am I using the bytes immediately prior to them (essentially ruling out a runover memory leak).
This problem is not dehabilitating... but it has been nagging me for a while. Does anyone have any ideas/theories as to why this may be happening?
Thanks,
Plloyd
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
heres the code. y this not working omega Programming 16 31-03-2004 15:18
C++ Code Error? Adam Shapiro Programming 9 20-01-2003 13:24
