Go to Post Its a good idea to learn to tame CAD monkeys. They're very useful. - Akash Rastogi [more]
Unread 09-04-2005, 19:05
1086Programmer's Avatar
1086Programmer 1086Programmer is offline
'Spirit Leader'
AKA: Sara Bailey
FRC #1086 (Blue Cheese)
Team Role: Marketing
1086Programmer will become famous soon enough1086Programmer will become famous soon enough
Send a message via AIM to 1086Programmer
Dual Joystick Code
My team is considering doing dual joysticks next year. I've been searching for anything on them, and I'm coming up dry. If anyone uses dual joysticks, and happens to have an old code, I'd really appreciate looking at it.
My coach wants me to get a headstart for next year and RoSi. ^_^
"Chad, duck tape's supposed to fix everything, right? What about programming errors?"
[font=Verdana]"You know, I love how we can just grunt, hum, and mumble, and still understand each other." Brian [FONT]
"I'm not making the phone call, you make the phone call!"
2005 † VCU Regionals Team Spirit Award
Unread 09-04-2005, 19:10
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Dual Joystick Code
well, dual joystick is very simple, there is no fancy code.
You should have searched there are many examples.
basically u need this in your user_routines.c
pwm13=p1_y;
pwm14=p2_y;
//Where pwm13 is the motor controlling one side of the robot and pwm14 is controlling the other.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 09-04-2005, 19:23
'Spirit Leader'
AKA: Sara Bailey
Really? That simple? Makes sense. Thanks.
I did search a bit, prolly not in the right places. ^^;
Unread 10-04-2005, 09:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Direct mapping of joystick to motor is the easiest and most intuitive way to use two joysticks to control two motors. This year's TechnoKat robot does it the long way around, though, taking the average of the two sticks to control an internal "velocity" value, with the sticks' difference becoming a "turn" value. It essentially computes the equivalent of a single joystick. The output code remixes the velocity and turn values into two motor control numbers.
This complexity has its rewards. It makes navigating under autonomous control a wee bit simpler to implement, and it provides a straightforward way to implement speed-sensitive steering if desired. There are deadbands applied to the computed values, so it also theoretically makes driving straight at high speed slightly easier.
Unread 10-04-2005, 13:26
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
FRC #0364 (Team Fusion)
jdhawg will become famous soon enough
Actually, if you take a look at the default code, dual driving joysticks are already in there. PWM01 is assigned the y value from Joystick 1 and PWM02 is assigned the y value from Joystick 2.
"Opportunity is missed by most people because it is dressed in overalls and looks like work." - Thomas A. Edison
"In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits." - Dave Lavery
Unread 10-04-2005, 13:37
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Would you share this code with us?
Unread 10-04-2005, 13:56
'Spirit Leader'
AKA: Sara Bailey
I see. I'm not quite sure that we're using the second joystick for though, whether it's driving or operating our pneumatics. That part they neglected to tell me, would it matter?
Unread 10-04-2005, 14:33
thoughtful's Avatar
It will , because everyone on this thread was under impression that you wanted two joysticks for driving the robot, as opposed to a single joystick for driving. If you just need another joystick for an arm here is what you need.
1. Make sure wether the arm is pneumatic, or motor.
2. If its motor, is it controlled by a victor or a spike.
If the arm is pneumatic or motor on a spike then:
relay1_fwd=p3_aux1;
relay1_rev=p3_aux2;
//here the single solenoid or the motor is on relay one.
If arm is on a motor contorlled by a victor then:
pwm03=p3_y;
// All the code is assuming that the joystick used is on port3.
06-Team 1219 Mentor
Unread 10-04-2005, 16:31
'Spirit Leader'
AKA: Sara Bailey
Okay. ^^;; Sorry for the confusion. I didn't know what I was looking for, my team coach didn't specify what he wanted.
Unread 10-04-2005, 21:22
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Why not just use one joystick at that point?
I personally like how with 2 joystick drive, you know how the bot will turn (with a bit of practice). How does your modified two-joystick really offer any advantage over two-joystick (other than the easier straight values)
As for the autonomous mode, you're not reading the pwms...so how does this make a difference in the end? (compared to using the standard one-joystick drive code)
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
need help w/ joystick code willie837 Programming 6 02-02-2005 23:17
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
